Forum topic by Dust | posted 02-08-2010 09:46 PM | 1603 views | 0 times favorited | 9 replies | ![]() |
I am trying to run a 23/32 dado stack, but the threads will not fully engage into the nut. It is only in about 1/2 an inch into the nut fully tightened. Is it acceptable to remove the arbor washer when running a dado stack to fully engage the threads? Or do I need to shorten the thickness on the stack? |
9 replies so far
#1 posted 02-08-2010 09:54 PM |
Do not run your saw without the washer! -- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas |
#2 posted 02-08-2010 09:58 PM |
Look in your instruction manual, most likely it says remove the washer that is placed before the nut. You cannot run a dado stack with the arbor washer because as you said the nut does not go on the arbor fully. It is common practice in industry as well as at home to run a stack without the washer. -- A hammer dangling from a wall will bang and sound like work when the wind blows the right way. |
#3 posted 02-08-2010 10:01 PM |
Some guys don’t have a problem with running a stacked dado without the washer. Check the manual for your saw and see what the manufacturer says. -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#4 posted 02-08-2010 10:29 PM |
There is a part that talks about installing a dado and it says: and another part that says: It does say when changing back to reinstall the outer blade washer, failure to do so can result in injury and damage. Never mentions any of the rest of the spacers and inner blade washer again. All I need to remove would be the out blade washer. The saw is a Ridgid 3650 if anyone is interested in that. |
#5 posted 02-08-2010 10:42 PM |
I remove the outer washer almost daily but I wouldnt touch any of the inner items. -- A hammer dangling from a wall will bang and sound like work when the wind blows the right way. |
#6 posted 02-08-2010 10:45 PM |
All saws I have ever owned you remove the washer. I do have a small plastic washer I use with my dado blade made to prevent from chewing up the dado blade. -- https://www.artisticwoodstudio.com/videos wood crafting & woodworking classes |
#7 posted 02-13-2010 03:28 PM |
On my Unisaw I remove the washer when cutting 3/4” dadoes, but use it for smaller ones. -- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com |
#8 posted 02-13-2010 04:02 PM |
Just remove the outer washer as stated. The arbor threads are counter clockwise so there is no danger of it coming loose. -- Julian, Park Forest, IL |
#9 posted 02-13-2010 04:13 PM |
No problem removing the washer. Just count on it falling in the sawdust when you do causing a 15 minute delay while you dig for it :) -- "The way to make a small fortune in woodworking- start with a large one" |
Forum | Topics |
Woodworking Skill Share
12035 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1372 |
Finishing
4909 |
6697 |
28075 |
CNC Woodworking
212 |
Hand Tools
5413 |
Jigs & Fixtures
1421 |
Wood & Lumber
6236 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2201 |
Coffee Lounge
8847 |
