T Square TS fence mod ?'s
Forum topic by ajthomas5009 posted 02-06-2016 01:16 PM 744 views 0 times favorited 5 replies Add to Favorites Watch
View ajthomas5009's profile
ajthomas5009
296 posts in 1821 days
02-06-2016 01:16 PM
Topic tags/keywords: jig question tablesaw
I need to reface my fence because the existing uhwm faces are beat up. Mine is the style where I can unbolt the faces from the bottom. Is there any reason I can’t replace the faces with some 80/20 bolted directly to the fence rail?
-- Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on.
5 replies so far
View knotscott's profile
knotscott
8150 posts in 3579 days
#1 posted 02-06-2016 01:56 PM
If you can figure a way to tighten the 80/20 flush to the tube, there’s no reason you can’t do it. You can also plane the UHWM faces to make the them smooth and flat again.
View jumbojack's profile
jumbojack
1685 posts in 2828 days
#2 posted 02-06-2016 02:21 PM
Joint and.run through your planer. Works a charm. This stuff cuts in longish strands and can clog the chutes.
View HokieKen's profile
HokieKen
7143 posts in 1342 days
#3 posted 02-06-2016 02:35 PM
I don’t see why you can’t drill and tap the fence or drill through and bolt from back. Curious why you want the 8020 on a table saw fence though? I think I would prefer a solid continuous surface.
-- Kenny, SW VA, Go Hokies!!!
ajthomas5009
#4 posted 02-06-2016 04:49 PM
The fence tube already has untapped holes so if I did it I was hoping to go with bolt washer and 80/20 thingy.
I’m not dead set on the 80/20 I just liked the idea of easily being able to attach kid/fixtures. Since I needed to do something with the current face it just popped in my head.
Thanks to the heads up on planing the faces. I might just do that until I make up my mind.
HokieKen
#5 posted 02-08-2016 07:22 PM
I m not dead set on the 80/20 I just liked the idea of easily being able to attach kid/fixtures…
- athomas5009
Never considered attaching a kid to the fence. Does that work better than featherboards? :>P
