Unisaw bolt size & pitch question
Forum topic by Fallon posted 02-08-2010 07:45 AM 1359 views 0 times favorited 8 replies Add to Favorites Watch
View Fallon's profile
Fallon
90 posts in 3126 days
02-08-2010 07:45 AM
Topic tags/keywords: question tablesaw unisaw
Does anybody know what size the 2 holes in the back of the table are for a 1986ish vintage Unisaw?
Trying to work up a mount for a cheap out-feed table I got that was missing it’s legs. Planning on putting some all-thread in the holes & drilling matching ones in the out-feed table & mounting it with wing nuts. However my hardware supply is lacking & I don’t have anything handy I can use to determine the size/pitch to get.
Unisaw hole
Devin
8 replies so far
117091 posts in 3575 days
#1 posted 02-08-2010 08:24 AM
Are they threaded?
Fallon
#2 posted 02-08-2010 05:24 PM
Ya, they are threaded on mine at least.
View Sawkerf's profile
Sawkerf
1730 posts in 3066 days
#3 posted 02-08-2010 06:31 PM
Those might be metric. If you have (or can get) your owners manual, it should tell you the size.
You could also find another bolt from the saw that fits those holes and take it to a hardware store. They usually have the gauges you need to match bolts.
Fallon
#4 posted 02-08-2010 06:49 PM
I pulled a couple bolts off this weekend, and none of them seemed to fit the holes. Ordered a set of thread gauges but those won’t be here for a bit.
Unfortunately the closest thing I have to a manual is http://www.owwm.com/pubs/1141/539.pdf, which doesn’t help on this front.
View Mickey Cassiba's profile
Mickey Cassiba
312 posts in 3029 days
#5 posted 02-09-2010 04:24 AM
‘86 was still a made in the US model. If you can send me a model and serial number I probably have the exploded art with part numbers,and perhaps sizes. I have the service manuals going back several decades.
-- One of these hammers oughta fix that...
Fallon
#6 posted 02-09-2010 04:55 AM
Serial # 88c16968 (there’s a chance the last 8 is actually a 6, as it was double stamped & hard to read)
Cat. No. 34-802
Sawkerf
#7 posted 02-09-2010 07:26 AM
Were the other bolts even close? Those holes might be gunked up enough so that even the right bolt won’t thread in.
A tap and die set might be useful. If you’re careful (i.e. don’t force it), the right tap will clean up the threads without messing them up.
Fallon
#8 posted 02-10-2010 06:01 AM
Nope, wrong size, either way to small or way to big.
