Bandsaw motor upgrade
Forum topic by opalko posted 02-08-2010 06:04 AM 1832 views 0 times favorited 4 replies Add to Favorites Watch
View opalko's profile
opalko
142 posts in 2942 days
02-08-2010 06:04 AM
I bought a Delta 28-203 bandsaw this weekend with an enclosed base. The bandsaw has a 3/4HP 1725 RPM motor. I’d like to upgrade to a 1 or 1.5 HP motor; what is involved? Can I just replace the motor and put the pulley from the old motor on the new one? Any recommended motors?
Thanks
116906 posts in 3484 days
#1 posted 02-08-2010 06:24 AM
Buy a more powerful band saw LOL
View MarkwithaK's profile
MarkwithaK
370 posts in 3085 days
#2 posted 02-08-2010 06:36 AM
The actual physical size of a larger motor will be a concern as is the mounting style. The motor size, expressed as frame size, between a 3/4 HP and a 1.5 HP is quite substantial. As Jim said, just get a bigger saw.
-- If at first you don't succeed then maybe skydiving isn't for you.
opalko
#3 posted 02-08-2010 01:22 PM
Not 100% sure of the dimensions, but this saw has an enclosed base and looks identical to the 475x model sold today with the 1.5HP motor. It is not like the 276 model with open stand sold in the box stores. I thought I saw an old Tools on Sale catalog once that showed this bandsaw and you could actually specify which size motor you wanted in it. I guess I’m looking for help from someone that knows the Delta bandsaw lineage a little better.
View Julian's profile
Julian
880 posts in 3432 days
#4 posted 02-08-2010 01:59 PM
I swapped out the stock 3/4 hp motor on my rigid bs for a 1 1/2 hp one. As long as you are getting a tefc motor with the same mount it will be fine. The motors aren’t any different in size. At least not enough to matter.
-- Julian, Park Forest, IL
