Table saw arbor flange runout
Forum topic by JonW posted 1227 days ago 2896 views 0 times favorited 5 replies Add to Favorites Watch
View JonW's profile
JonW
8 posts in 1313 days
1227 days ago
Topic tags/keywords: table saw arbor runout tablesaw
I have a Ridgid TS2424; there is no measurable shaft runout, but the flange that the blade rests against (one piece with the shaft), has 4-5 thousandths runout which results in ten thousandths runout at the edge of a new 10” Freud blade. To fix it, I could buy a new arbor assembly at around $110, or remove the assembly and take it to a machine shop; but shouldn’t it be possible to rest a file or stone against the flange (in the table) to clean it up? Shouldn’t it just hit the high spots, and level it as would a machinist’s lathe? One other thought is to put some sort of soft washer between the flange and the blade, so that it self-aligns against the outer washer instead of the inner flange. Any thoughts or suggestions would be welcome.
5 replies so far
89117 posts in 1775 days
#1 posted 1227 days ago
Your could try putting some of the the self adhesive metal type duct tape the kind made form thin metal on the low side of the flange and see if that evens it out.
View JonW's profile
JonW
#2 posted 1224 days ago
Thanks Jim! Sometimes the simplest fix is the best. On re-checking, I found I’d not been quite touching the shaft when I thought it had no runout. Both shaft and flange have runout, which I re-measured at about .015 at the blade edge – quite visible when it is rotated slowly.
Trying your suggestion, I found that it took only a very very thin “shim” to be effective; after a lot of trial and error, I ended up with two thicknesses of tissue paper to bring the runout down to .003” which is satisfactory to me.
Jon
View jerryz's profile
jerryz
164 posts in 1476 days
#3 posted 1224 days ago
There was a post not long ago that mentioned this same issue, the solution for the flange runout was to place the arbor at 45 Deg and lift it so that by attaching a stone to piece of wood perpendicular to the flange and turning on the TS you would carefully remove the high spot on the flange.
As for the arbor runout make sure you measure it right at the spot were the blade is tightened with the nut.
You should be able to fix those issues permanently I would hate having to shim and reshim evey time I replace the blade.
Update!
Found that article: http://lumberjocks.com/topics/14440 and also the link that was provided courtesy of a1Jim
http://woodgears.ca/saw_arbor/index.html
Be safe
View Milo's profile
Milo
813 posts in 1517 days
#4 posted 1224 days ago
Jon!
Call Ridgid and see if that TS isn’t on recall for that very problem. Ridgid replaced my arbor for free last year beause of a prblem with the threading on the arbor. Perhaps yours is cover too.
Milo
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
View Sawkerf's profile
Sawkerf
1730 posts in 1266 days
#5 posted 1224 days ago
Jon -
IMO, a “soft washer” would be the worst possible fix for this problem. Blades want to follow the path of least resistance while cutting and I can visualize cutting into a knot (or really tightly grained wood) and having the blade deflect even more than usual because of a “soft washer”.
Shimming might work, but I wouldn’t want to re-shim for each blade change and I doubt if I would be very comfortable using a shim with a stacked dado cutter. And, you probably couldn’t pay me enough to use a shim with a wobble dado cutter. – lol
I would check with Ridgid about this. There may be a recall, or they may have a better solution. Quite honestly, I would spend the $110 before I tried some home made fix.
