Pin Nailer
Forum topic by Milled posted 02-05-2016 04:28 AM 807 views 0 times favorited 11 replies Add to Favorites Watch
View Milled's profile
Milled
43 posts in 1493 days
02-05-2016 04:28 AM
I have some 1/4” wide by 1/8” thick strips that I want to pin nail at the ends without splitting. Sometimes it works, sometimes not. Any suggestions?
-- If it's doable, I'll do it...if it's been done, I've done it...if it's impossible, I'll try it.
11 replies so far
View jumbojack's profile
jumbojack
1673 posts in 2494 days
#1 posted 02-05-2016 04:29 AM
Dampen the wood first?
Milled
#2 posted 02-05-2016 04:31 AM
Jumbo, good idea. I’ll try it tomorrow. Thanks,
woodbutcherbynight
3731 posts in 2279 days
#3 posted 02-05-2016 04:50 AM
I have taken a small dab of glue and some tape and glued them in place rather than use a nail. Of course if you ever want it off, it is wood glue which does not really ever want to come apart. LOL
View jerryminer's profile
jerryminer
846 posts in 1311 days
#4 posted 02-05-2016 05:42 AM
Orientation of the gun matters. place the pins so the “chisel point” is facing perpendicular to the wood grain (cutting fibers rather than wedging between)
Milled
#5 posted 02-05-2016 06:52 AM
Thanks for the suggestions…
View MrRon's profile
MrRon
4560 posts in 3113 days
#6 posted 02-05-2016 05:35 PM
- jerryminer
Pin nailers use 23 gauge pins which are round in cross section. You must be confusing pin nailers with 18 gauge brad nailers.
View AlaskaGuy's profile (online now)
AlaskaGuy
3756 posts in 2179 days
#7 posted 02-05-2016 07:16 PM
- jerryminer
- MrRon
You sure about that Ron? These 23 ga pin nail are not round and do have a chisel point.
View Cooler's profile
Cooler
299 posts in 713 days
#8 posted 02-05-2016 07:41 PM
I used to assemble picture frames with cross pinned corners. I used conventional brads and pre-drilled. It is probably your only sure way to avoid splitting.
The drill bits snap easily so you need to buy several at a time. United Manufacturers Supply sells them very cheaply along with the wire brads.
See: http://www.unitedmfrscatalog.com/lg_display.cfm/catalog/Catalog_772_Revised/page/62
and: http://www.unitedmfrscatalog.com/lg_display.cfm/page/19/catalog/Catalog_772_Revised
Here is the price list: http://www.unitedmfrs.com/cart/price_list.cfm
you need to look up the part number on the price list. It is a pain to use but their prices are very good.
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
View Gart's profile
Gart
27 posts in 1286 days
#9 posted 02-05-2016 07:42 PM
Use a clamp across the strip where you are shooting the pin. The power will have to go forward, through the strip versus being able to split the wood laterally.
Gart
View bondogaposis's profile
bondogaposis
4524 posts in 2221 days
#10 posted 02-05-2016 07:56 PM
Pin it in place first, then cut it to length.
-- Bondo Gaposis
View JackDuren's profile
JackDuren
364 posts in 829 days
#11 posted 02-07-2016 03:39 PM
It’s the grain you have to watch when pinning the pieces. Follow the grain create a split. It’s like driving a wedge…
