Help! Unisaw Top!
Forum topic by LittleLyle posted 02-05-2016 01:35 AM 1205 views 0 times favorited 28 replies Add to Favorites Watch
View LittleLyle's profile
LittleLyle
4 posts in 751 days
02-05-2016 01:35 AM
Topic tags/keywords: unisaw table saw delta united tablesaw
Hello.
I recently acquired a United NBR-455 10” tilting arbor saw. People have told me it is a Japanese knockoff of the old delta unisaw, and in fact it does look very similar. I need a tabletop for it, can you guys tell me whether or not a delta unisaw table top will fit on this saw? The bolt holes are ~ 19.5” apart in the short dimension and 21” apart for the long dimension. Anyone have a delta unisaw tabletop
Thanks
Andy
Sent on the go.
28 replies so far
View TheWoodRaccoon's profile
TheWoodRaccoon
364 posts in 838 days
#1 posted 02-05-2016 02:12 AM
Are you saying that the entire cast iron top is gone? If yhat’s the case, i don’t think you should have bought the saw…
-- still trying to think of a clever signature......
LittleLyle
4 posts in 751 days
#2 posted 02-05-2016 02:21 AM
Yeah it’s gone. Was more of a gift, i just paid for transport to my shop. Nah man there has got to be a way to figure this out! It’s a great saw still just needs a surface.
View Richard's profile
Richard
1916 posts in 2599 days
#3 posted 02-05-2016 02:30 AM
Photos might help someone more than the measurements or along with them.
View ThomasChippendale's profile
ThomasChippendale
244 posts in 841 days
#4 posted 02-05-2016 02:39 AM
Just measured my Unisaw and its close but not close enough to fit your measurements.
-- PJ
View 716's profile
716
502 posts in 825 days
#5 posted 02-05-2016 02:43 AM
Just make one from melamine.
-- It's nice!
View TarHeelz's profile
TarHeelz
58 posts in 1990 days
#6 posted 02-05-2016 02:48 AM
One has to wonder what great story explains a table saw losing its cast iron top. Not a part typically lost or to otherwise go missing.
-- Tar Heelz, Durham, NC USA
View bigblockyeti's profile
bigblockyeti
4994 posts in 1629 days
#7 posted 02-05-2016 03:02 AM
I too would like to hear how one looses the table from a table saw. Kinda reminds me of seeing various car parts on the side of the road, mufflers I totally get especially up here in the rust belt, hubcaps with the non-existent road maintenance, that too make sense. Brake drums just befuddle me, the real question is brake discs where on over 99% of vehicles the caliper would first have to be removed to get the disc off. How in the heck does that happen?
View jumbojack's profile
jumbojack
1673 posts in 2533 days
#8 posted 02-05-2016 03:32 AM
My son’s girlfriend drove her van to my place because of ‘break’ noise. I pulled the wheel and caliper. Inboard pad was GONE. Outboard pad was nearly worn through. Rotor was worn enough to see the back side if the cooling fins. The only thing stopping the right front was the actual caliper contacting the rotor. Needless to say they BOTH got an Ass chewing. Replaced both rotors both calipers.
That is how you find weird parts on the highway.
jumbojack
#9 posted 02-05-2016 03:38 AM
Oh and about your table saw:
LittleLyle
4 posts in 751 days
#10 posted 02-05-2016 04:45 AM
View TheFridge's profile
TheFridge
8908 posts in 1395 days
#11 posted 02-05-2016 04:51 AM
It might take some work but I don’t see why not.
View FancyShoes's profile
FancyShoes
550 posts in 1273 days
#12 posted 02-05-2016 04:57 AM
That is a delta knock off for sure! Im sure they took the actual dimensions from the unisaw. However, most the time when you measure between 2 holes, you measure from center of the holes.
View MrUnix's profile
MrUnix
6373 posts in 2108 days
#13 posted 02-05-2016 05:14 AM
Rough measurement of the two front holes comes up with approx 18.25” center to center. Your saw is different than the Uni in that it has tabs to mount the table, while the Uni has a solid flange around the top:
If yours had the solid flange, it would make it easier as you could re-drill the holes as needed… but with the tabs, you might get it to work, but I doubt it will be as simple as just bolting it on.
PS: It may be considered a Japanese knockoff of the Unisaw by some, but it’s not at all the same. There are more significant differences than just how the table mounts to the cabinet; such as the way the trunnions mount, their brackets, the yoke, etc…
View splatman's profile
splatman
586 posts in 1308 days
#14 posted 02-05-2016 06:55 AM
If that tableless TS were in my possession, I would make a table for it out of quartz coutertop material. (Offcuts and sink/range cutouts are free from most countertop shops) Probably the next best thing to cast iron.
I would not use granite; most granites are too brittle.
Web-search how to work quartz coutertop material, if you are interested.
Maybe start with a temporary plywood top, if for no other reason than to check that it can function like a TS, before investing any $$ or effort into sourcing or making a top.
View SirIrb's profile
SirIrb
1239 posts in 1139 days
#15 posted 02-05-2016 11:37 AM
“Hey dad, I took your table saw for a spin and when I got home I noticed the top was gone. Just gone. I dont know where it is.”
showing 1 through 15 of 28 replies
