HELP-- Polyurethane crystalizing white
Forum topic by ckwoodworking posted 02-05-2016 01:35 AM 760 views 0 times favorited 11 replies Add to Favorites Watch
View ckwoodworking's profile
ckwoodworking
4 posts in 804 days
02-05-2016 01:35 AM
Topic tags/keywords: cedar tiger wood
Does anyone have an answer for this??
I applied two coats of Minwax natural wood stain to my table top.. waited about 72 hours then applied the Minwax Wipe on Poly (with a green cotton tshirt).. certain spots turned crystalized white that I could scratch off with my finger nail. I scraped it all off then sanded and reapplied a DIFFERENT brand new can of Poly (same brand) and the SAME THING HAPPENED.. its driving me insane—it takes so long to scrape off..
Does anyone have a quick solution or know why this is happening? I really hope I can apply something to it to fix it instead of scraping it all off again. PLEASE HELP!!
11 replies so far
View Bob Kassmeyer's profile
Bob Kassmeyer
221 posts in 2887 days
#1 posted 02-05-2016 01:42 AM
Have never seen it before but the only thing I can think of would be some contamination on the piece. I believe the only solution is what you do not want to do take it off, clean and reapply.
-- Bob Kassmeyer, Nebraska
View conifur's profile
conifur
955 posts in 1113 days
#2 posted 02-05-2016 01:49 AM
I use both and never experienced that, what species of wood is it?
ckwoodworking
4 posts in 804 days
#3 posted 02-05-2016 02:26 AM
Could the temperature of a room cause this to happen??
I do it in my garage which is about 8-12 degree C.
The wood is cedar from Home Depot and the tiger wood is from the local timber store (not exactly sure the species)
conifur
#4 posted 02-05-2016 02:58 AM
In my experience with your finishes low temp just slows down drying time, yes I know, a winter shop 50-60*F
as I said never experienced it, but just use hard woods, I think it is something in the wood. With that said if it was Shellac then it gets cloudy in high humidity situations. But you are saying more like cystals, I think some thing is bleeding out of the wood IMO.
ckwoodworking
4 posts in 804 days
#5 posted 02-05-2016 03:08 AM
conifur-
The odd thing is, is that it is crystalizing on both the tigerwood and cedar…
If you were to finish a kitchen table.. what would you do.. im going to strip the top
View KYSean's profile
KYSean
119 posts in 3558 days
#6 posted 02-05-2016 03:41 AM
Either old poly or moisture in the wood somehow.
-- http://editedwrite.com
View mahdee's profile
mahdee
3868 posts in 1729 days
#7 posted 02-05-2016 12:02 PM
I am thinking it is the oil in cedar. The aromatic ones do that naturally. You may have to heat up the cedar and let it bleed most of the oil before you proceed. If you are using water base poly, switch to oil base one for this project.
-- earthartandfoods.com
KYSean
#8 posted 02-05-2016 03:05 PM
remove all finsih. Rub the wood down good with Acetone and put one coat of finish on right after cleaning. Let it dry 24 hours. If the white is gone, your good to apply more coats of finish.
conifur
#9 posted 02-05-2016 04:20 PM
Tiger wood and if aromatic cedar, which I have not worked with, have allot of oil in them. From I have read in my Finishing books, as previously posted here, I would wipe them down with Naphtha or Acetone at least once, then a wash coat of 1 1/2 lb cut of Shellac then top coat of your choice. Try it on a sample piece first and see what the result is.
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1138 days
#10 posted 02-05-2016 04:26 PM
+1 to what conifer said.
Shellac is a great sealer of wood and between different types of finish. If you want to keep the colors “as is” you will want to consider a blonde or super blonde color of shellac.
ckwoodworking
4 posts in 804 days
#11 posted 02-05-2016 07:53 PM
Thanks for the help everyone.. I got creative last night and got some wax paper along with an iron and ironed over the areas of white crystals.. They disappeared and have not come back.. Not sure if this is a new thing I figured out… but either way.. its worked! Hopefully this solution can help others!
