outfeed table suggestions
Forum topic by BB1 posted 02-04-2016 12:04 AM 941 views 0 times favorited 10 replies Add to Favorites Watch
View BB1's profile
BB1
972 posts in 752 days
02-04-2016 12:04 AM
I’m looking to build an outfeed table for my table saw. Hoping for some suggestions on the best way to attach. Right now I do move the saw around so something removable would be ideal but realize that I might need to miss out on mobility to enhance safety. The picture shows the saw back view.
10 replies so far
View hotbyte's profile
hotbyte
991 posts in 2879 days
#1 posted 02-04-2016 12:12 AM
Make it freestanding and fold-able legs. Then you will have mobility for each as needed.
View 716's profile
716
502 posts in 820 days
#2 posted 02-04-2016 12:15 AM
I just use a $35 utility table from Costco. Works like a charm and unlike specialized outfeed tables can be moved around or away from the saw for longer stock, turned with shorter or longer end to the saw, and with a table cloth still used for its intended purpose in case you have a suprize! visit from your relatives.
-- It's nice!
View BB1's profile
BB1
#3 posted 02-04-2016 01:48 AM
Thanks for the suggestions. Hoping to have a table that actually attaches so the surfaces are level. Right now I have some brackets that I can clamp on a saw horse but does not feel as stable as I would like.
View Kent's profile
Kent
150 posts in 1700 days
#4 posted 02-04-2016 02:14 AM
Have you checked out the Paulk Workbench yet? It’s designed to be portable AND your table saw would ‘hang’ off the bench, creating the desired outfeed table that you want. Here’s a link to one of many already here on LJs.
-- If I knew then what I know now, I'd have made a completely different set of mistakes.
View BB1's profile
BB1
#5 posted 02-04-2016 03:12 AM
Thanks for the link. Hadn’t considered anything along those lines…interesting option….
View Yonak's profile
Yonak
986 posts in 1425 days
#6 posted 02-04-2016 03:36 AM
+1 for 716’s suggestion. You could fashion a way for the mobile cart to attach to the saw and unattach so it could be rolled around to double as a mobile assembly or work table. At the right height it could also be an outfeed table for your planer. I have three rolling carts that can work in concert or be attached together to make a larger assembly platform.
View MacB's profile
MacB
38 posts in 1544 days
#7 posted 02-04-2016 04:07 AM
i had the exact same saw. at the time i was doing on site cabinet building and installation. i thought about building an outfeed table for it, but since i wanted a 50” rip capacity i purchased the rousseau ts stand. bc i was so impressed with the stand, i ended up ordering (2) outfeed tables. they were like $150 at the time. the saw, with the stand, cut as accurately as a cabinet saw. the rousseau outfeed tables had a U shaped hook that would rest on the square shape tubing of the ts stand. it would lift off. bc it was a jobsite saw, it wasn’t that big of deal that the outfeed tables where 1/4” lower than the ts itself. i did not do much bevel ripping which requires perfectly flush support on the outfeed side. i sold this saw on craigslist, so i cant give you very good picks on how the outfeed table attached. but this is the pic i have, maybe you can get an idea.
View 716's profile
716
#8 posted 02-04-2016 04:22 AM
This is the one, cheaper than hinges to a dedicated outfeed table, plus to everything mentioned above capable keeping a lot of junk even when the saw is put away.
-- It's nice!
View BB1's profile
BB1
#9 posted 02-04-2016 12:43 PM
I appreciate all the suggestions and now need to critically look at my space and see what I can fit. Like MacB’s setup (going to check that source). Also need to look more at the idea of Yonak and 716 for something multipurpose/mobile.
View MarkTEvans's profile
MarkTEvans
1 post in 746 days
#10 posted 02-04-2016 02:07 PM
I’m actually going to start building something similar to TWW's first outfeed table. I’m planning to add locking casters so I can wheel it around as needed and use it for more than just and outfeed table. However, being that you have the portable type table saw, I would definitely look into the Paulk Table and hang the saw off the end.
