Big Gulp
Forum topic by 716 posted 02-03-2016 11:43 PM 1249 views 0 times favorited 22 replies Add to Favorites Watch
View 716's profile
716
502 posts in 825 days
02-03-2016 11:43 PM
Did anyone managed effectively use this thing on a table saw ?
-- It's nice!
22 replies so far
View hotbyte's profile
hotbyte
991 posts in 2884 days
#1 posted 02-04-2016 12:15 AM
For overhead/above table use? I would think one of the designs that are just over blade would work better.
If below table, there is a more flat square looking DC adapter.
View Kelly's profile
Kelly
1922 posts in 2853 days
#2 posted 02-04-2016 12:22 AM
I have as much luck drawing off the bottom port and setting second [4”] hose near the blade [when I can’t use the overarm collector].
I picked up a trip pod like someone would use in a presentation and attached a pieces of plywood to the top, which has a cut-out to hold the hose. This allows me to set it up near the table saw, band saw or a item being sanded.
View ohtimberwolf's profile
ohtimberwolf
750 posts in 2261 days
#3 posted 02-04-2016 01:28 AM
Kelly, a picture would be nice. larry
-- Just a barn cat, now gone to cat heaven.
ohtimberwolf
#4 posted 02-04-2016 01:30 AM
716, I built one nearly like that using a metal slanted roof flange and it keeps the under-neith part of the saw clean. I would have bought that if I had known about it.
Kelly
#5 posted 02-04-2016 03:34 AM
Will try to tend that, ohtimberwolf, before I head off out tomorrow.
Kelly
#6 posted 02-04-2016 05:21 PM
ohtimberwolf, I staged some photos to show you my use of a presentation tripod to position a secondary hose for dust collection.
Since the tripod can raise and lower, it’s easy to position it lower for the table saw or sanding, or raise it for the band saw.
4885 posts in 2402 days
#7 posted 02-04-2016 06:38 PM
I could see that being useful for a miter saw (maybe) and an RAS, I use mine on the lathe (when sanding). Not sure how I would use it on a table saw.
View 716's profile
716
#8 posted 02-04-2016 08:27 PM
- Fred Hargis
Like this ?
-- It's nice!
Kelly
#9 posted 02-04-2016 08:35 PM
If your collector has any significant draw, setting it near or in the path the dust and chips not being pushed or pulled down the band saw or table saw plates results in vastly improved dust and chip collection than relying on the stock only the stock ports.
When I was cutting tenons, I just set it nearly straight behind the blade and it reduced the tossings from the blade to a fraction. That actually worked better than having the hose very close to and at the side of the blade, in that situation. When I was cutting logs on the band saw, with the blade on the right side of the log, for example, it grabbed everything that would have gone air born, when the hose was about five inches off the blade and log.
Each cutting operation might require a minor or major shift, but that’s just the name of the game. The stand just allows me to position the hose somewhere and have it stay, whether it’s at a sander, scroll saw or whatever.
Kelly
#10 posted 02-04-2016 08:48 PM
I tried a bigger hood and a wider hood (floor sweep), but both gained me less than focusing the collection point with just the hose.
My sanding station, on the other hand, needed a hood, on a larger scale, to focus collection and still be of use. To work on my table saw, a hood would have to go over the blade, like my over-arm collector, but such an approach proves impossible with the tenon jig and impractical in others.
Another thing that would improve the table saw collection would be increasing the draw area around the throat plate, without losing the zero clearance effect.
http://lumberjocks.com/projects/195330
Kelly
#11 posted 02-04-2016 08:52 PM
I might mention, for my lathe, I made a couple, like in your drawing. One is for short work and one for longer work. Rather than tall, since little is tossed off high when turning and that would reduce efficiency, I kept them small, to get them as close to the work as possible. From the back, it catches all the light stuff, when sanding, and a little, when turning.
Later, I’m going make one which comes up from the bottom front, and that should get the draw closer. I might start off with a shop floor (wide) nozzle to get a feel for the effect and to determine what I can get away with without interfering with the turning operation. At least that’s the theory.
Kelly
#12 posted 02-04-2016 09:28 PM
I might mention, for my lathe, I made a couple, like in your drawing. One is for short work and one for longer work. Rather than tall, since little is tossed off high when turning, and that would reduce efficiency, I kept them small, to get them as close to the work as possible. From the back, it catches all the light stuff, when sanding, and a little, when turning.
Later, I’m going make one which comes up from the bottom front, and that should get the draw closer. At least that’s the theory.
ohtimberwolf
#13 posted 02-04-2016 10:11 PM
Thanks for the pictures as it makes it easy to see how it is done. I will try it. larry
View 716's profile
716
#14 posted 02-05-2016 12:06 AM
- Kelly
You mean like the one below? May not be effective as the dust that does not fall inside the cabinet is thrown forward away from the throat plate. By the time it slows down enough for the dust collector suction to catch it is too far from the plate.
-- It's nice!
View splatman's profile
splatman
586 posts in 1307 days
#15 posted 02-05-2016 03:47 AM
Might help to have fewer holes at the back and more holes at the front. Most dust that lands on the table usually lands near/around the front anyway (experience).
Another idea worth testing: A series of holes centered on the blade slot, such that the slot edges resemble the edges of an old-fashioned postage stamp. The idea is to combine the performance of a zero-clearance plate with the (probable) effectiveness of downdraft holes right at the source of the dust.
