How to decide on lathe HP
Forum topic by yellowtruck75 posted 02-03-2016 06:39 PM 531 views 0 times favorited 5 replies Add to Favorites Watch
View yellowtruck75's profile
yellowtruck75
469 posts in 3030 days
02-03-2016 06:39 PM
I am thinking about upgrading my lathe but I can’t decide if the 1.5 or the 2 horse power is better. Like most machines I am steering towards the 2 horse power because the higher the horse power the better but I don’t know if that is always the case with lathes. I currently have a Jet Mini Lathe that is .75 horse power. The two models I am debating between is the Jet Model JWL-1642EVS, 1-1/2 HP and the Jet Model JWL-1642EVS-2, 2HP. Both are pretty much the same machine except for the horse power. I always admired bowl turners so I would like to play around with that but also want to be able to turn large (~4” thick) table legs.
Thoughts?
5 replies so far
View TheDane's profile
TheDane
5399 posts in 3626 days
#1 posted 02-03-2016 06:46 PM
Go for the bigger, more powerful motor. You’ll get more torque and are less likely to labor the motor when taking heavier cuts.
View pmayer's profile
pmayer
1026 posts in 3028 days
#2 posted 02-03-2016 07:40 PM
If you’re not bothered by needing a 220V outlet, I’d go with 2HP. If you’re turning large bowls, you’ll like having that extra torque.
yellowtruck75
#3 posted 02-04-2016 11:38 AM
pmayer I set my shop up so that for every double 110 outlet I have a 220 outlet.
View OSU55's profile
OSU55
1624 posts in 1952 days
#4 posted 02-04-2016 12:47 PM
6” table legs won’t require as much power as a 10” bowl (once at speed). I turn 15” bowls with 3/4 hp without a problem. Not sure of the price difference, but since you have 220V, go for the 2 hp.
pmayer
#5 posted 02-04-2016 02:14 PM
Good move yellowtruck! Then definitely go for a 220V!
