flattening chisel backs - question
Forum topic by HokieMojo posted 02-07-2010 01:54 AM 2459 views 0 times favorited 13 replies Add to Favorites Watch
View HokieMojo's profile
HokieMojo
2104 posts in 3723 days
02-07-2010 01:54 AM
I should know this already, but I don’t. I’ve recently purchased a few king waterstones. i’ve got the following grits: 800, 1000, 4000, 6000. On my 1/4 and 1/2 inch chisels, I could use the 800 to remove the machine marks from my craftsman chisel. Then I could easily go through the remaining grits to get a mirror finish. It did take a bit of time (30 minutes for each back) but after getting it flat, the rest of the stones went quickly.
My problem is on the 1.25 inch chisel. I must have spent 2 hours on the back using the 800, but I’m not having much luck. the problem is that when looking at the back, it is convex. It is really tough to get the front edge to start getting smooth. what i’m wondering is this. Do I need a rougher stone? I really want to stick to water stones. i’ve done scary sharp and oil stones, but I really like the water stones. any ideas?
13 replies so far
View papadan's profile
papadan
3584 posts in 3363 days
#1 posted 02-07-2010 01:58 AM
If it is that bad, I would use a slow wet grinder. Then use your stones to finish it.
117090 posts in 3572 days
#2 posted 02-07-2010 02:03 AM
If you going to use stones an it’s taking that long, Yes you need a rougher stone or you need to do the initial flatting on a grinder.
View sphere's profile
sphere
109 posts in 3026 days
#3 posted 02-07-2010 02:04 AM
I have used a brass hammer to help coax an unflat back , back into shape. Much as one does to tweak the hollows on Japanese chisels.
-- Spheramid Enterprises Architectural Wood Works
View Julian's profile
Julian
880 posts in 3520 days
#4 posted 02-07-2010 03:12 AM
I use a 6” wheel made out of mdf than I put on my slow speed grinder. I apply red rouge to the side and hold the back of the chisel against the side of the wheel. Once the back is mirror shiny I then proceed to do the same thing to the bevel. Both procedures only take a minute to do. I can go from grinding a new bevel to the mdf wheel without changing a thing and produce an edge that will easily take the hair off my arm. I haven’t had to use the scary sharp method since I learned this method and with the mdf wheel I can touch up a dull edge quickly and efficiently so I can back to what I am in the shop to do, work!
-- Julian, Park Forest, IL
View RHutch's profile
RHutch
5 posts in 3049 days
#5 posted 02-07-2010 04:11 AM
Now that sounds like something I should try Julian.
-- Hutch, Rhode Island
View lwllms's profile
lwllms
555 posts in 3276 days
#6 posted 02-07-2010 04:41 AM
Glue some 60 or 80 grit silicon carbide or Norizon paper to something flat and work the chisel down with that. If you don’t have access to that, cut a sanding belt in half and use it. Make sure and glue it down. It won’t take much effort to remove the abrasive signatures of the sandpaper with your coarse stone but you really want to get that back flat before you move back to your stones.
View 8iowa's profile
8iowa
1580 posts in 3756 days
#7 posted 02-07-2010 05:02 AM
I also like to use water stones. However, for the initial prep of a chisel or plane iron, I have a series of flat glass plates with 50 to 1200 grit paper “gued” on with 3M77. Note, 3M90 is very permanent.
I only go down to 50 grit on old & beat up tools. For a new chisel I would start with 150 or 180 and then progress thru 220, 320, 400, 600, 800, and then to 1200 if you want to finish the surface on the glass plates. I find that 1200 gives a mirror finish on the steel. This saves a lot of wear on your water stones.
View JayPique's profile
JayPique
61 posts in 3283 days
#8 posted 02-07-2010 05:07 AM
I do the paper on glass thing as well when I first lap my chisels and plane blades. I use PSA 100, 120, 150 and 180 grit and then move to automotive paper right on up through 2000. I’m a bit picky about it the first time, but you really only need to do it once so you might as well get it right. From that point forward I just touch it up on my finest waterstone – a 12,000 grit Shapton. (Still haven’t sprung for the 30k!)
JP
View RandyMarine's profile
RandyMarine
236 posts in 3364 days
#9 posted 02-15-2010 08:03 PM
Could I glue the sand paper to my Granite top TS? never having used any of this stuff before, does the bonder between the flattop and the paper peel away after?
-- Semper Fi, Randy Sr.
HokieMojo
#10 posted 02-16-2010 05:11 AM
not what i wanted to hear, but thanks for the honesty. I’m trying a few things to see if i can get the stones to work sufficiently. I’m just out of money to buy anything more, no matter how cheap it may sound. oh well. thanks guys.
View russv's profile
russv
262 posts in 3164 days
#11 posted 02-16-2010 11:16 PM
Hokie,
plain and simple, first time grinding it flat can sometimes take alot. just spray adhesive some cheap 80 grit sandpaper to some MDF and sand away. after that, run thru your wet stones. won’t take long. after initially flat, you won’t ever need the 80 grit sandpaper (or MDF) again. the sandpaper on mdf will work fine, cheap and fast.
russv
-- yknotwood.com: where to go because you don't want no stinking plastic!
View rwyoung's profile
rwyoung
409 posts in 3466 days
#12 posted 02-16-2010 11:55 PM
Hokie -
Make sure your stone is FLAT while you are working on the backs of the chisels. If you are working at a chisel for that long, you are probably also putting a hollow in the stone. Stop once in a while and flatten the stone.
-- Don't sweat the petty things and don't pet the sweaty things.
View rtb's profile
rtb
1101 posts in 3708 days
#13 posted 02-17-2010 12:02 AM
For old or really beat up one I like to flatted then on the belt sander and then go up thru the grits
-- RTB. stray animals are just looking for love
