Pallet Wood Smoker Cabinet
Forum topic by flippyaforeal posted 02-02-2016 04:18 PM 1061 views 0 times favorited 5 replies Add to Favorites Watch
View flippyaforeal's profile
50 posts in 799 days
02-02-2016 04:18 PM
I have erected a cabinet around my Bradley Smoker. Once I am finished with the build what do I seal the pallet wood with? It wont be outside all the time but I want it to be protected. The sides are Pallet wood, roof will also be finished in wood shingles made with cut down pallet pieces. Looking for low cost.
5 replies so far
View Milled's profile
43 posts in 1557 days
#1 posted 02-04-2016 04:40 AM
-- If it's doable, I'll do it...if it's been done, I've done it...if it's impossible, I'll try it.
View Matt's profile
160 posts in 885 days
#2 posted 02-04-2016 01:16 PM
Bacon Grease…. Yumm!!!!
-- My "projects" always look better with beer goggles.
View dhazelton's profile
2722 posts in 2231 days
#3 posted 02-04-2016 02:07 PM
I don’t think you have enough of a pitch for wood shakes on the roof. Put a layer of self sealing membrane on it first.
How long WILL it live outside? If it ever rains the water will get past the cracks and end up rusting your tool box. It also looks like you used regular black drywall screws which will rust. If you don’t want a lot of streaking you should put a hard finish on it like poly or spar varnish. If you don’t mind the wood and screws weathering then just use Thompsons once or twice a year.
#4 posted 02-04-2016 06:11 PM
It will only be outside while in use. Made the cabinet because it rains quite a bit here and if it does get left out overnight it wont get swamped. I like the membrane idea, thanks.
#5 posted 02-08-2016 08:21 PM
Here is a picture of the finished roof.
