Help with name for a type of bolt
Forum topic by woodguy1980 posted 02-02-2016 01:24 PM 1492 views 0 times favorited 17 replies Add to Favorites Watch
View woodguy1980's profile
woodguy1980
6 posts in 964 days
02-02-2016 01:24 PM
Hi everyone,
I’m working on a project that is using a bolt that is screwed/unscrewed to adjust a part horizontally. The spacing is fairly tight and adjustments would be much easier if I had a turn knob that was above the screw. If you look at the symbols below, the 3 + signs would be the knob. If you’re looking down on the knob from above, it should turn clockwise to tighten the bolt and counter-clockwise to loosen the bolt.
I’ve tried searching online but can’t seem to find anything that would work. Does anyone out there know the name of this type of bolt/setup and where I could buy some?
+++ (knob)
|=========== (bolt)
Thanks
17 replies so far
View bondogaposis's profile
bondogaposis
4929 posts in 2471 days
#1 posted 02-02-2016 01:29 PM
Huh, from your description I have no idea what you are talking about.
-- Bondo Gaposis
View MrUnix's profile
MrUnix
6889 posts in 2318 days
#2 posted 02-02-2016 01:29 PM
Thumbscrew?
View TheWoodRaccoon's profile
TheWoodRaccoon
364 posts in 1049 days
#3 posted 02-02-2016 01:43 PM
I’m pretty sure you mean a “hand wheel” or “crank”, right?
-- still trying to think of a clever signature......
View HokieKen's profile
HokieKen
6172 posts in 1258 days
#4 posted 02-02-2016 06:08 PM
From the description, I think the OP wants a knob that is at a right angle to the bolt. If that’s the case, I don’t know of a simple solution. Bevel gears of some sort but how to mount/mate them could be tricky if you’ve got limited space.
-- Kenny, SW VA, Go Hokies!!!
View MadMark's profile
MadMark
979 posts in 1572 days
#5 posted 02-02-2016 06:22 PM
Worm gear
Link
M
View Bill White's profile
Bill White
5054 posts in 4080 days
#6 posted 02-02-2016 07:03 PM
Now let’s see…......
I don’t see.
No help here without a pic of some sort.
Bill
-- bill@magraphics.us
View Kent's profile
Kent
162 posts in 1915 days
#7 posted 02-02-2016 07:08 PM
Check out Matthias Wendal’s page on making right angle gears. Between the video and the text, you should have a starting point for your mod.
-- If I knew then what I know now, I'd have made a completely different set of mistakes.
View Woodknack's profile
Woodknack
12338 posts in 2499 days
#8 posted 02-02-2016 09:17 PM
View oldnovice's profile
oldnovice
7133 posts in 3487 days
#9 posted 02-03-2016 12:25 AM
Does this project of mine help?
bandit571
21072 posts in 2803 days
#10 posted 02-03-2016 12:29 AM
Picked these bolts up today..
View Pointer's profile
Pointer
427 posts in 1230 days
#11 posted 02-03-2016 01:42 AM
If I’m hearin’ what you’re sayin’, I think MadMark’s post is the closest thing to what you are talking about.
-- Joe - - Don't be pessimistic, it never works works anyway.
View distrbd's profile
distrbd
2252 posts in 2566 days
#12 posted 02-03-2016 02:22 AM
could it be something like a drill depth collar or shaft collar?
Or mirror arm extender screw:
-- Ken from Ontario, Canada
View 716's profile
716
502 posts in 1036 days
#13 posted 02-03-2016 02:45 AM
-- It's nice!
View 716's profile
716
#14 posted 02-03-2016 02:51 AM
Oh I got it ! It is a guitar tuner. Right ?
-- It's nice!
woodguy1980
6 posts in 964 days
#15 posted 02-03-2016 05:43 AM
Sorry about the unclear description. I guess I should have drawn a quick sketch in paint. However, with my drawing skills, it may have caused even more confusion.
MadMark and 716 are spot on with what I was referring to. In fact, a guitar tuner with some slight modifications may be the ticket. The bolt I’m using is relatively small (6-32) so I think the size of a guitar tuner would be a good starting point.
Aside from searching for guitar tuners, would the technical name for this be a worm gear? Just trying to determine the best way to search for different sizes.
Thanks again everyone!
