wood owl nail chipper
Forum topic by joez posted 02-02-2016 03:43 AM 673 views 0 times favorited 7 replies Add to Favorites Watch
View joez's profile
120 posts in 2835 days
02-02-2016 03:43 AM
Topic tags/keywords: split wood
Hello does anybody know why the wood owl nail chipper bit Auger Bit (1-1/2” x 7-1/2”) – Nail Chipper Tri Cut by Wood Owl , spilt the hard maple I was drilling?
7 replies so far
View Picklehead's profile
1041 posts in 1861 days
#1 posted 02-02-2016 11:57 AM
I think the screw, which runs ahead of the cutting flutes, split the board just as if you were screwing in a screw of that size without drilling a pilot hole, because, in essence, you were.
-- You've got to be smarter than the tree.
View Tennessee's profile
2807 posts in 2446 days
#2 posted 02-02-2016 12:44 PM
Picklehead is exactly right. The screw started the split since it was going into virgin uncut wood, and with that small split, the large flutes finished the job.
View joez's profile
#3 posted 02-02-2016 01:01 PM
so would a pilot hole for the screw make a difference?
View bigblockyeti's profile
5051 posts in 1652 days
#4 posted 02-02-2016 01:19 PM
They are typically used by electricians to drill holes in construction lumber to run romex and plumbers running pipe. The nail chipper aspect of the bit is an improvement over regular self feed bits as they can be damaged or destroyed when hitting nails. These bits aren’t designed for making nice neat holes, they’re designed for speed. The angle of the taper and pitch of the thread of the self feeding screw is designed for use in pine and douglas fir in mind.
View joez's profile
#5 posted 02-03-2016 12:46 AM
So what’s the alternative for drilling hard maple this size?
View patcollins's profile
1676 posts in 2797 days
#6 posted 02-03-2016 12:56 AM
So what s the alternative for drilling hard maple this size?
- joez
Forstner bit if you want a nice hole, hole saw if you don’t care how ragged the hole is.
View Tim's profile
3758 posts in 1893 days
#7 posted 02-03-2016 01:26 AM
If you don’t need the nail chipper feature, the regular wood owl bits with cutting spurs on the end cut an extremely nice hole. Especially if you stop just as the lead screw comes out the other side of the wood, turn it over and come in from the other side.
But to answer your second question, yes, a pilot hole makes all the difference to keep an auger bit from splitting wood. Make sure it’s a little smaller than the thickest part of the lead screw and you’ll be good.
