How tall mortise/tenon can be.
« back to Joinery forum
Forum topic by 716 posted 02-01-2016 04:10 PM 1174 views 0 times favorited 11 replies Add to Favorites Watch
View 716's profile
716
502 posts in 1150 days
02-01-2016 04:10 PM
In a glued application how wide the apron board can be before the wood expansion becomes a problem. Let’s say for hard maple material.
-- It's nice!
11 replies so far
View jeth's profile
jeth
262 posts in 3071 days
#1 posted 02-01-2016 04:25 PM
Hello.. probably about 3 inches or so would be the limit before you would want to allow for movement, dividing the tenons and only partially gluing, as you get wider (think breadboard ends as an example) using pegs through slotted holes in tenons to secure etc.
They look like sliding dovetails(??) not straight tenons, if you’re worried you could just glue the top end or not glue at all in that case as the mechanical joint of the tail will stop them sliding out. Probably be best to glue at least an end so the legs can’t slide off!
117416 posts in 3811 days
#2 posted 02-01-2016 04:35 PM
Jeth said exactly what I would recommend.
View Woodknack's profile
Woodknack
12455 posts in 2614 days
#3 posted 02-01-2016 04:44 PM
I made a table with a 4.5” apron, been ten years and no issues. Mahogany, which is pretty stable.
View 716's profile
716
#4 posted 02-01-2016 05:17 PM
Thank you all. that was very helpful!
-- It's nice!
View bonesbr549's profile
bonesbr549
1579 posts in 3301 days
#5 posted 02-01-2016 05:23 PM
I would add that its material dependent as well. If the apron material is QS then movement will be greatly reduced and some species are more volitile than others. Tight grained woods would be the best. IMO. I’ve done aprons 6” no issues, however I follow a rule, and any cross grain situation exists I allow for some movement period.
View pintodeluxe's profile (online now)
pintodeluxe
5815 posts in 3047 days
#6 posted 02-01-2016 05:34 PM
A 6” wide piece of bigleaf maple will change dimensions by approximately 1/32” (depending on how it was cut) as moisture content changes from 6% to 10%. I usually use wide rails on side panels for bookcases and and the like. In those instance I may or may not split the tendon. That depends more on leg thickness than expansion / contraction. You can glue only the center of the tendon if you wish, but I think for board width < 6” in an air conditioned house, wood movement is negligible.
I haven’t had the occasion to make aprons wider than 4-5”, and have never had a problem. I use quartersawn stock though, which is usually more stable.
Clever tool for calculating mood movement…
http://www.woodbin.com/calcs/shrinkulator/
View hotbyte's profile
hotbyte
991 posts in 3209 days
#7 posted 02-01-2016 05:55 PM
Woodknack
#8 posted 02-01-2016 06:41 PM
Results of the anvil test mentioned in the article linked above.
http://www.popularwoodworking.com/techniques/the_anvil_test
hotbyte
#9 posted 02-01-2016 07:16 PM
- Rick M.
They really need videos of the anvil drops and splinters flying :)
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2603 days
#10 posted 02-01-2016 08:20 PM
I’ve done a 4” wide drawbored tenon in cherry on my daughter’s bed going on 2 years now and no signs of any issues.
Woodknack
#11 posted 02-01-2016 08:53 PM
- hotbyte
Matthias! Get in here!!
