Staining, poly or nothing
Forum topic by MikeOB posted 02-05-2010 02:57 PM 1340 views 0 times favorited 7 replies Add to Favorites Watch
View MikeOB's profile
MikeOB
89 posts in 3030 days
02-05-2010 02:57 PM
I am almost done with my 1st project – my mobile work bench. Here is a picture from Nov 09 wood mag.
http://ep.yimg.com/ca/I/woodstore_2093_37319433
I have a light colored, almost like this picture, solid core door that I’m going to use for the top instead of the 2×4s.
Any suggestions on what I should use? I want to keep it light colored, but then again a dark bottom light top would work too.
I’m kinda new to this so any suggestions would be nice.
Face is pine, shelves and sides are birch plywood.
Thanks
-- Mike, Portage, WI
7 replies so far
View Waldschrat's profile
Waldschrat
505 posts in 3345 days
#1 posted 02-05-2010 03:34 PM
if you are new at wood working and are looking to put an easy finish on your bench, I would suggest oil or (tung oil for example). Its easy to apply and does not require spraying, and goes relative quick. not to mention, if is going to get a bit scratched or dinged up, if you want to spiff it up in the future a light sanding and a bit more oil is easy and quick for time to time maintence.
-- Nicholas, Cabinet/Furniture Maker, Blue Hill, Maine
View suds1421's profile
suds1421
6 posts in 3040 days
#2 posted 02-05-2010 03:37 PM
I would put on “Witches Brew”, easy to put on and easy to repair….
(1/3 boiled linseed oil, 1/3 gloss poly and 1/3 naptha).
116913 posts in 3486 days
#3 posted 02-05-2010 04:54 PM
Wipe on poly
View PurpLev's profile
PurpLev
8534 posts in 3558 days
#4 posted 02-05-2010 05:00 PM
Boiled linseed oil – like Barry mentioned, slippery workbenches (hard finish like poly or laquer) won’t hold your work pieces as securely.
boiled linseed oil is easy to apply like Nicholas mentioned, in penetrates the wood and seals it against moisture, but still leave that soft warm wood feel to it.
it WILL however darken the wood. the only thing that I know of that won’t darken the wood is water based finishes like waterbased-poly. but I would not use that for a workbench.
View Mogebier's profile
Mogebier
170 posts in 2942 days
#5 posted 02-05-2010 05:06 PM
My work bench is for working, not looking at, so I just put a couple of coats of gloss white primer on it just to protect the wood from spills. It’s very rough looking and “worked on” :)
-- You can get more with a kind word and a 2 by 4, than you can with just a kind word.
View Icemizer's profile
Icemizer
88 posts in 3449 days
#6 posted 02-05-2010 05:46 PM
I also use a solid core door and covered it with some Varathane Floor Finish. Better at handeling scuffs and scratches. Also a little less smooth than the stuff used for furniture.
-- Say what you mean and mean what you say.
MikeOB
#7 posted 02-06-2010 12:10 AM
thanks for the advice!
