Need Dimensions for Dewalt 735 Planer
Forum topic by BrettSherm posted 02-01-2016 01:52 PM 3871 views 0 times favorited 10 replies Add to Favorites Watch
View BrettSherm's profile
BrettSherm
6 posts in 812 days
02-01-2016 01:52 PM
Topic tags/keywords: dewalt 735 planer stand
I’m building a stand for my future Dewalt 735 Planer. I’d like to get working on the stand before I purchase the planer. Can anyone give me the dimensions? Width (Meaning the side that you run the wood through), Depth (the other dimension) and height from the bottom to the planing table. There will be adjustability built into the stand with the height to the outfeed tables, so I don’t have to get it dead even at first, just close.
Thanks in advance.
10 replies so far
View syenefarmer's profile
syenefarmer
486 posts in 3045 days
#1 posted 02-01-2016 02:00 PM
Found this doing a Google search, hope it’s correct.
Width = 27”, height = 14”, depth = 23” (tables folded-up) The handle sticks-out about 4” (in the 27” dimension).
View sawdustjunkie's profile
sawdustjunkie
382 posts in 1682 days
#2 posted 02-01-2016 06:22 PM
The folding table on the exhaust side will not fold up completely, because the port is in the way, so don’t make it to narrow.
Mine sits up on my bench, so I have room on both sides to pass stock through it.
-- Steve: Franklin, WI
View nerdbot's profile
nerdbot
97 posts in 1326 days
#3 posted 02-01-2016 06:42 PM
I took this off some quick measurements off of my DW735. Width is about 21.5”, not including the handle, depth (from front to back of built in table – not the folding in- and out-feed tables) is about 19.75”, and the height from the bottom to the top of the tables is about 2 5/8”.
View WhyMe's profile
WhyMe
1008 posts in 1525 days
#4 posted 02-01-2016 08:28 PM
If it helps… the Dewalt stand is 24”W X 21”D X 29.25”H.
BrettSherm
6 posts in 812 days
#5 posted 02-01-2016 08:32 PM
Thanks nerdbot. That’s a great help. I’m planing to go without extension tables and instead building it into the stand.
View Milled's profile
Milled
43 posts in 1588 days
#6 posted 02-01-2016 09:55 PM
Brettsherm, I wouldn’t build the stand until I had the 735 in hand. If you’re building the infeed and outfeed tables the measurements will need to be exact…not “about”.
-- If it's doable, I'll do it...if it's been done, I've done it...if it's impossible, I'll try it.
View Jim Finn's profile
Jim Finn
2647 posts in 2886 days
#7 posted 02-02-2016 02:54 AM
I have adjusted the infeed and out-feed Panels to omit snipe on mine and it works well now. I also suggest you get the planer , get it adjusted, and then make the infeed and out-feed benches for it, as needed.
-- Website is https://craftingcouple.com/
WhyMe
#8 posted 02-02-2016 02:37 PM
2.66 inches from top of planer table to bottom of base. That’s using a caliper on my 735.
View Jac28up's profile
Jac28up
2 posts in 11 days
#9 posted 04-10-2018 02:51 PM
Has anyone ever tried to mount a Dewalt 735x to a Bosch TS2100 gravity rise table? I’m thinking about doing it for portability.
View diverlloyd's profile
diverlloyd
2657 posts in 1822 days
#10 posted 04-10-2018 02:52 PM
Has anyone ever tried to mount a Dewalt 735x to a Bosch TS2100 gravity rise table? I m thinking about doing it for portability.
- Jac28up
Try starting a new thread the option is under you name in the upper right of the page.
Welcome to the site
