counterboring a 2 5/16" hole?
Forum topic by Bugzy posted 01-31-2016 11:39 PM 688 views 0 times favorited 8 replies Add to Favorites Watch
View Bugzy's profile
Bugzy
10 posts in 1407 days
01-31-2016 11:39 PM
Afternoon,
Recently purchased a Veritas front Vise that require a couple 2 5/16” counter bored 1/2” holes to insert a circular brace/support. How would you drill these holes? Just getting into woodworking a little more serious.
The only thing I can think of Is a hole saw an chisel, as I can’t find a bit big enough.
I I missing something obvious?
8 replies so far
View bandit571's profile
bandit571
19972 posts in 2679 days
#1 posted 01-31-2016 11:48 PM
Forstner Bit?
And, if you have a brace type drill, an expansive bit can cut that big a hole.
View Ger21's profile
Ger21
1074 posts in 3127 days
#2 posted 01-31-2016 11:53 PM
Drill a hole in some plywood or MDF with a hole saw, and either screw it or stick it to your part with double sided tape, and use it as a template with a top bearing pattern router bit.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
Bugzy
#3 posted 01-31-2016 11:55 PM
Thank you!
I had never heard of a forstner bit before. I’m going to look into it as appears to be what I need as long I can get the correct dia.
Lumberjocks does it again!!
View BUBBATAY's profile
BUBBATAY
57 posts in 2310 days
#4 posted 01-31-2016 11:59 PM
You might want to also look into a Irwin expansion bit. It would be more versatile foe future use
View MadMark's profile
MadMark
979 posts in 1449 days
#5 posted 02-01-2016 12:01 AM
Forstner bit is the right tool:
M
BUBBATAY
#6 posted 02-01-2016 12:59 AM
View gfadvm's profile
gfadvm
14940 posts in 2686 days
#7 posted 02-01-2016 01:33 AM
That Forstner bit is pretty pricey to drill 2 holes. I have used the template/router method and it works great.
Bugzy
#8 posted 02-01-2016 01:40 AM
I just added the router and router table to my arsenal a couple months back so I may use this as an excuse to add another bit to the library.
Thanks for all the help and recommendations. The hole saw and plywood/hardwood template is a great idea….. again new to a lot of these ideas.
Cheers everyone,
