Unisaw Arbor Run-out
Forum topic by mw7018 posted 01-31-2016 07:33 PM 691 views 0 times favorited 4 replies Add to Favorites Watch
View mw7018's profile
mw7018
19 posts in 868 days
01-31-2016 07:33 PM
Topic tags/keywords: unisaw fine-tuning run out
I am in the process of setting up my recently acquired Unisaw 34-450.
After installing new arbor bearings, I re-installed the assembly and it is very smooth. Using my dial indicator, I come up with a .006 ‘wobble’ as measured at the edge of the fixed flange on the arbor while rotating it slowly. The arbor appears to be straight.
Any suggestion on the best way to address this?
Mike
View AlaskaGuy's profile
AlaskaGuy
4135 posts in 2307 days
#1 posted 01-31-2016 07:39 PM
Do a google search on “trueing up a abor on a table saw”. There’s a ton of how to’s and videos.
MrUnix
6714 posts in 2197 days
#2 posted 01-31-2016 07:39 PM
Check here for one option:
Fixing the wobble in a table saw arbor
mw7018
#3 posted 01-31-2016 08:22 PM
Great input guys.
I have the arbor out of the saw and will see if I can get it machined before re-installing.
Hopefully this will eliminate the need to ‘tune’ it in the saw. Makes you appreciate the need to be gentle with things you want to be precise.
Mike
mw7018
#4 posted 02-12-2016 03:50 AM
New bearings for the arbor and motor installed. Running smooth!
Amazied at the difference from my Craftsman. Now, building a runout table and then cabinets for our Butler’s Pantry.
My 24 year old son was skeptical about my purchase of a 47 year old saw, but after helping rebuild and seeing the performance he had to admit his admiration for the quality of the saw.
