Will stainless steel bolts rust & seize up?
Forum topic by WoodNSawdust posted 01-31-2016 06:50 AM 1239 views 0 times favorited 16 replies Add to Favorites Watch
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1170 days
01-31-2016 06:50 AM
Topic tags/keywords: stainless steel bolts rust
Today got up into the 60s so I decided to start with an outdoor project – replacing the broken wood handle on my wheel barrow.
For the last few weeks I have regularly sprayed the nuts with WD-40 hoping that they will become loose. They did not.
So my question is will stainless steel bolts and nuts rust and seize up over a period of years when left outside?
Thanks in advance,
16 replies so far
View JKMDETAIL's profile
JKMDETAIL
211 posts in 1649 days
#1 posted 01-31-2016 11:56 AM
If they are a higher grade of stainless then no. If they are magnetic they have a potential to rust. Not nearly to the extent of other materials. If they have magnetic qualities they have a small amount of iron in them which will rust.
WoodNSawdust
#2 posted 01-31-2016 12:33 PM
It would seem obvious that it is the rust that is causing the bolt and nut to seize?
View tomsteve's profile
tomsteve
783 posts in 1213 days
#3 posted 01-31-2016 02:22 PM
since the handles broken and getting replaced, put a propane torch on the nut for a bit(a minute or 2). usually doesnt take too much heat to break it loose.
View TheFridge's profile
TheFridge
9444 posts in 1480 days
#4 posted 01-31-2016 02:30 PM
No. If they’re over tightened the threads will booger up and you have to cut or break them.
View dhazelton's profile
dhazelton
2766 posts in 2290 days
#5 posted 01-31-2016 02:36 PM
Use a grinder to cut them off.
View shipwright's profile
shipwright
7979 posts in 2792 days
#6 posted 01-31-2016 02:53 PM
Stainless steel is about 75-80% iron but is protected from corrosion by the inclusion of alloying elements, primarily chromium. That said it is suceptable to two specific kinds of corrosion, crevice corrosion and pitting. In both cases it will corrode freely, even marine grades.
New SS corrdes on its surface immediately forming a thin “passivated” film that protects it from further corrosion.This film can be damaged mechanically (like tightening a nut on a bolt) and if the new surface doesn’t have access to the atmosphere to re-passivate it will corrode just like any other steel. This happens on underwater boat fittings all the time.
The good news is that your shovel won’t likely be in seawater so you will be fine with most SS grades, certainly better than plain steel.
View Bluepine38's profile
Bluepine38
3379 posts in 3079 days
#7 posted 01-31-2016 05:51 PM
Stainless steel will have a greater tendency to gall, or sieze up because of friction between the bolt and the
nut, than to sieze up due to rust and corrosion in the open air. If the area you are in has a corrosive
atmosphere, you could use T316 stainless bolts instead of the normal 18-8 grade which is usually what is
available. One of the mills used to use regular plated nuts on the stainless bolts because of the galling issue
with stainless.
View Greg the Cajun Wood Artist's profile
421 posts in 936 days
#8 posted 01-31-2016 06:20 PM
Another option is to use bronze bolts and nuts..
-- Wood for projects is like a good Fart..."better when you cut it yourself"
WoodNSawdust
#9 posted 01-31-2016 09:40 PM
- dhazelton
That is what I did. I was hoping that I could find a type of bolt that would not seize up when the handle has to be replaced again in 5 – 10 years.
Since it did not sound like stainless would satisfy my requirements and the cost differential I went with simple bolts and will cut them off again when needed.
View splatman's profile
splatman
586 posts in 1393 days
#10 posted 01-31-2016 11:01 PM
Would putting anti-seize compound on the threads prevent galling?
dhazelton
#11 posted 02-01-2016 12:17 AM
Goober a bunch of silicone on them if you want.
TheFridge
#12 posted 02-01-2016 12:21 AM
- splatman
Yep
View ThomasChippendale's profile
ThomasChippendale
244 posts in 926 days
#13 posted 02-01-2016 01:05 AM
Anti-Seize is the answer, for SS zinc based instead of copper based but its harder to find.
-- PJ
WoodNSawdust
#14 posted 02-01-2016 01:23 AM
Are there different types of Anti-Seize compounds? I have one for high heat automotive applications.
View bandit571's profile
bandit571
19956 posts in 2677 days
#15 posted 02-01-2016 01:28 AM
Maybe a wrap or two of Teflon tape on the bolt?
