too much satin?
Forum topic by bmalloy posted 01-31-2016 05:15 AM 673 views 0 times favorited 6 replies Add to Favorites Watch
View bmalloy's profile
bmalloy
3 posts in 757 days
01-31-2016 05:15 AM
Topic tags/keywords: walnut arm-r-seal
Hi, I am attempting to make my first table. Here is a post w/ some pics: http://lumberjocks.com/bmalloy/blog/77226
So I purchased a can of arm-r-seal because of all the positive things I have read. I am not a fan of glossy things so I got a can of satin. I also read that I can skip the seal-a-cell if I cut the arm-r with 20% mineral spirits. I was planning on doing one coat with the cut arm-r-seal and then apply 2 or so more at full strength.
I am wondering if all that satin is gonna hide the black walnut more than I want?
I will do a few test sections at the bottom of the desk… i just don’t know if all that satin is a bad thing and I shouldn’t bother.
View DMC1903's profile
DMC1903
285 posts in 2236 days
#1 posted 01-31-2016 05:22 AM
The satin Arm-a-Seal will look very nice on the walnut, follow the directions on the container. Do Not dilute!!!
View bbasiaga's profile
bbasiaga
1124 posts in 1903 days
#2 posted 01-31-2016 05:25 AM
I am fond of some natural color danish oil with 3 coats of Arm R Seal over that. I too prefer a non glossy surface.
Brian
View RobS888's profile
RobS888
2390 posts in 1753 days
#3 posted 01-31-2016 01:18 PM
Brian
- bbasiaga
I like the medium walnut Danish oil with arm-r-seal on it.
I have done 9 coats on a window sill and it still looks great.
This pic is of the top of a radiator cover, 4 coats of satin.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
View jdmaher's profile
jdmaher
418 posts in 2488 days
#4 posted 01-31-2016 03:06 PM
Don’t dilute Arm-R-Seal.
I only use a sealer if I have to. I infrequently will dye or even less frequently stain, but I often will use an oil to enhance grain and/or color. If I do any of that, I put a coat or two of 1 lb. shellac on top of it, to seal between finishes. Then the Arm-R-Seal.
But if I’m NOT staining or oiling the bare wood, I go straight to Arm-R-Seal – UN-diluted.
I usually use a couple coats of gloss, then a satin. But I’ve done three coats of satin and was quite happy.
-- Jim Maher, Illinois
bmalloy
3 posts in 757 days
#5 posted 01-31-2016 07:29 PM
Thanks DMC1903, bbasiaga, RobS888, and jdmaher!
I’ve done 0 finishing before so it is nice to read it is ok it go right at it.
I guess the idea of diluting it is to mirror the diluted seal-a-cell for a first deep soak. The pdf info for the products says you can dilute it: “Reducer/Thinner: Mineral Spirits (10 -20%) if necessary”. I have also seen Charles Neil mention soaking 15-20% to get a deep soak. I guess I run the risk of making it too thin and having it run off the table? Are these the reasons you guys are against the idea?
https://generalfinishes.com/sites/default/files/file_downloads/Tech-Data-GF-Arm-R-Seal-050311.pdf
Thanks again.
jdmaher
#6 posted 01-31-2016 07:56 PM
To me, in my environment, Arm-R-Seal goes on easily (no streaks or brush marks), self-levels and leaves a pretty smooth film surface. That is, I like how I use it, how it goes on. Thinning would change the way it “works” / goes on.
Although everything soaks in to bare wood, somewhat, if I really want penetration to enhance color or make the grain “pop”, I use an oil (e.g., Watco, Waterlox) – then seal that with shellac before Arm-R-Seal.
