Leg joinery for live edge walnut slab table
Forum topic by Ropelie posted 01-30-2016 08:54 PM 727 views 0 times favorited 1 reply Add to Favorites Watch
View Ropelie's profile
30 posts in 1106 days
01-30-2016 08:54 PM
I just started building a table from a design my sawyer showed me. This is featuring black walnut slabs from a tree my grandfather planted when my father was just born. Since he has passed we harvested the tree before selling the house and are building legacy furniture out of it.
I am seeking advice on attacking the single leg to the 12/4 table base. The single leg will be three 8/4 pieces glued together and shaped. I have attached the picture of the table I based the design off of.
I’m not even sure the name of the joint. The closest joint it resembles is probably a bridal joint? Currently planning on cutting a dado out of the base and the leg and simply gluing with some screws for reinforcement. Do you guys think theirs enough long grain to long grain with this method?
I am open for suggestions because I want this to be the right decision!
and a picture of the base wood before glue up
I felt a little bad cutting these down to length. My helper did the cleanup from jointing.
1 reply so far
View ThomasChippendale's profile
244 posts in 867 days
#1 posted 01-30-2016 09:22 PM
Cross Lap Joint with a big lag screw right up the center, you will probably use the same technique for the table top supports.
-- PJ
