Printing on wood surface
Forum topic by RGood posted 01-30-2016 08:01 PM 709 views 0 times favorited 5 replies Add to Favorites Watch
View RGood's profile
RGood
2 posts in 3096 days
01-30-2016 08:01 PM
Gentlemen, I have a friend who just got married and she had all her friends hand write little message (in ink) on a slab of wood, and she ask me to put a topcoat of finish on it to preserve it. My question is: If I spray some type of finish on it, will it make the ink run and ruin the piece? but if I can spray, what is the suggested topcoat to use.
Thank you
Rick Good
-- Rick Good, Illinois, www.b0ggieb0y@sbclobal.net
5 replies so far
View cracknpop's profile
cracknpop
294 posts in 2345 days
#1 posted 01-30-2016 10:10 PM
Rick, I have sprayed lacquer sealer over my signature on the bottom of some pieces I have made. A typical wet coat will begin to blur the edges of the ink. Probably not what I would do on the Bride’s keepsake board.
My suggestion would be to take a similar piece of wood and write on it with similar pen/marker and make a “Test Board”. Try spraying very light coats of spray shellac and see if that changes the ink appearance/makes it run. Can also try spraying very light coats of lacquer or poly as well. All may add an amber tint to your wood.
If you are near an art store, they may have other options to try. Regardless, I would use on Test Board first.
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
View Kelly's profile
Kelly
2025 posts in 2940 days
#2 posted 01-30-2016 10:18 PM
I used to do a lot of this (bought my two part epoxy in five gallon cans). If I used a spray, I’d mist it several times, rather than coat it all in one shot.
Generally, I used Elmer’s glue to seal many things. It both held newspaper and such to the wood and sealed the print [I put a layer over the top after the glue holding the print dried], which kept the print from the other side from bleeding through, but which it would do, if the print were saturated with oil or other finish.
You can thin the glue just a little to reduce thickness to just a mil or two, after it’s dried.
View Jim Finn's profile
Jim Finn
2656 posts in 2918 days
#3 posted 01-31-2016 12:47 AM
I also just “Mist” the first two coats of finish over my, stamp pad applied, name.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
RGood
#4 posted 01-31-2016 03:49 AM
Crcknpop, Kelly and Jim, thank you for your responses, good advice on all 3 counts and I Will take them into consideration.
RGood
View Coaster36's profile
Coaster36
5 posts in 843 days
#5 posted 01-31-2016 04:25 AM
Good advise.
