sharpening stone ?
Forum topic by MNWOODWORKER posted 02-04-2010 08:34 AM 2605 views 0 times favorited 11 replies Add to Favorites Watch
View MNWOODWORKER's profile
MNWOODWORKER
105 posts in 3614 days
02-04-2010 08:34 AM
With one of my oilstones it doesn’t seem to matter how much oil I put on it because it just absorbs it right in. I can’t get a slurry going because of it, any suggestions? I have tried useing honing oil and WD40.
thanks
11 replies so far
117128 posts in 3606 days
#1 posted 02-04-2010 08:40 AM
I thought they neaded to be stored in oil
View RHutch's profile
RHutch
6 posts in 3083 days
#2 posted 02-04-2010 11:47 PM
I have one like that. I’m curious what kind of oil would be best to soak it in to stop this.
-- Hutch, Rhode Island
View cliffton's profile
cliffton
117 posts in 3110 days
#3 posted 02-05-2010 02:32 AM
My father (a real carpenter) always used that 3 in 1 oil in a tin can. to keep the stone “wet” he made a wooden case for it that you filled the bottom with oil and it would soak it up.
View mcase's profile
mcase
446 posts in 3158 days
#4 posted 02-05-2010 06:28 AM
honing oil is simply mineral oil. I used to use 3 in 1 and it certainly works, but not as well. The problem nowadays is finding pure mineral oil without stinky perfume mixed in.
View Daren Nelson's profile
Daren Nelson
767 posts in 3935 days
#5 posted 02-05-2010 04:10 PM
Silly question…but are you sure it is an oil stone, not a water stone ?
View MattinCincy's profile
MattinCincy
128 posts in 3182 days
#6 posted 02-05-2010 08:07 PM
Pure mineral oil (without stinky perfume mixed in) is available at every pharmacy in the U.S. – and it’s cheap.
-- Wag more, bark less.
View Tim Dahn's profile
Tim Dahn
1567 posts in 3594 days
#7 posted 02-05-2010 09:15 PM
Mineral oil is also available at the grocery store, and is about half the cost of the Pharmacy.
View jackass's profile
jackass
350 posts in 3742 days
#8 posted 02-05-2010 10:00 PM
I use an Arkansas stone, oil does not absorb, in fact you have to wipe it off after use. Gives me a nice edge on my knives and blades. I tried oil and water stones and find they hollow out too soon. I have one Arkansas that is 20 years old and still flat as a board. It gets lots of use. I wouldn’t use anything else.
Jack
-- Jack Keefe Shediac NB Canada
MNWOODWORKER
#9 posted 02-08-2010 11:16 AM
I tried the mineral oil and made a small box like cliffton said and it took care of the problem, but man did it soak in a lot before stabilizing. With my other stones I never had that problem but read that some stones are filled before they are sold, I know thi one must not have been because there was no residue on it at all when I got it. Thanks a lot guys for the input. Jack, what kind of Arkansas stone do you have?? I have a small fine White Arkansas stone that is perfect for my chisels but since it is only about 1 3/4” it is too small for planes. It seems to be that most people really like the Black Arkansas stones, any input??
Nate
View iamwelty's profile
iamwelty
259 posts in 3145 days
#10 posted 02-08-2010 03:04 PM
I use a Smith’s Tri-Stone set up… get’s me to a 1000 grit, which is good enough for what I do… It was around $25 at Lowe’s
http://smithsedge.com/products/product.asp?id=35&cid=4
-- There is a fine line between eroticism and nausea...
View sphere's profile
sphere
109 posts in 3060 days
#11 posted 02-08-2010 03:11 PM
Oil stones don’t want slurry, that is for water stones.
Oil stones want the oil to help keep the stone fresh cutting, slurry will clog it.
Natural stones ( arkansas) are much better at not drinking up the lube than man made ones.
You can use almost any oil, I used scented lamp oil, kero and motor oil mixed, 3-in-1, anything. Flush the stone once in awhile with diesel fuel or kero to CLEAN it. A wire brush or toothbrush ( the wife’s not yours) helps keep it from glazing over.
-- Spheramid Enterprises Architectural Wood Works
