miter saw blades
Forum topic by 3285jeff posted 01-30-2016 04:02 PM 661 views 1 time favorited 4 replies Add to Favorites Watch
View 3285jeff's profile
3285jeff
152 posts in 1715 days
01-30-2016 04:02 PM
What is the best saw blade to use on a miter or radial arm saw,,,I was told a blade with a 7 degree negative rake, ,,can anyone recommend a good one,,and I would like to thank everyone that supplied me with info on how to set up and align my craftsman radial arm saw,,,thank you ever so much,,,,,
View Gene Howe's profile
Gene Howe
10479 posts in 3426 days
#1 posted 01-30-2016 04:09 PM
Freud LU91M. Made specifically for the sliding miter saw. Would work fine on a RAS as well.
Here's an ad for one.
runswithscissors
2751 posts in 2022 days
#2 posted 01-30-2016 11:11 PM
Since you don’t do a climbing cut (unlike a RAS) with a slider, I wonder if the negative hook is really an advantage. Maybe a cleaner cut?
View builtinbkyn's profile
builtinbkyn
2278 posts in 938 days
#3 posted 01-30-2016 11:32 PM
I just put one on my saw. I really like it. Clean cuts even in veneered plywood. I had an 80T Freud on prior, but it didn’t cut as clean in plywood as this blade.
Here s an ad for one.
- Gene Howe
-- Bill, Yo!......in Brooklyn & Steel City :)
View knotscott's profile
knotscott
8013 posts in 3373 days
#4 posted 01-31-2016 12:57 PM
For a RAS and SCMS, a blade that has a low positive to negative hook angle is recommended. It doesn’t have to be specifically -7° (which could prove hard to find anyway). It’s probably best if it’s not more than +5°, which should give you a nice selection of good blades to choose from.
I’ve been totally impressed with several Infinity blades…assuming 10” blade, their 60T Hi-ATB, 80T Ultrasmooth Hi-ATB, or 80T 010-280 Miter-Max are all excellent choices. The Ultrasmooth should leave the cleanest cut of those, the 60T will also be excellent and will cut a little faster, and the Miter-Max should cut cleanly and have slightly better edge life. The Freud LU91 is a solid choice, and their LU80 should be similar to the Infinity Ultrasmooth. Forrest also has some excellent choices in the WWI, Duraline, and Chopmaster, albeit more expensive.
