Lumber Core Plywood
« back to LumberJocks.com Site Feedback forum
Forum topic by ziller posted 02-04-2010 05:48 AM 1299 views 0 times favorited 3 replies Add to Favorites Watch
View ziller's profile
ziller
69 posts in 3000 days
02-04-2010 05:48 AM
Topic tags/keywords: question plywood
Hello Lumber Jocks,
I am trying to gain as much info on lumber core plywood as I can. I am doing a project for a designer that requires that I don’t use any MDF products. The project involves some good sized slab type doors that I would usually build out of MDF plywood. Even a good domestic veneer core plywood doesn’t stay quite flat enough for this application. I am wondering if a lumber core would do the trick. Any info is appreciated and thanks in advance for your time.
-- Zach, Las Vegas
3 replies so far
View bobkberg's profile
bobkberg
439 posts in 2977 days
#1 posted 02-18-2010 06:04 AM
My inclination would be to go to the other extreme, and use a european cabinet grade plywood like 7 or 9 ply. The more plies in a given piece of wood (allowing for good manufacturing process control), the more stable the end product is going to be, since no one ply exerts a particular dominance over any other, and they’re all “fighting” one another.
That said, you didn’t mention how thick the end product has to be, or what the tolerances are for warpage and such.
If the end product needs to be of a particular thickness, solidity, or density, it may be reasonable to consider other core materials besides wood. One of my favorite materials is garolite (see mcmaster.com). It’s not cheap, but it’s VERY stable, and can be cut with woodworking tools. It’s also tough enough to drill and tap – some people make gears with it.
-- Bob www.singularengineering.com - A sideline, not how I earn a living
TopamaxSurvivor
18191 posts in 3580 days
#2 posted 02-18-2010 06:12 AM
Do they make wood faced garolite? I saw copper faced.
View John Ormsby's profile
John Ormsby
1283 posts in 3641 days
#3 posted 02-18-2010 06:27 AM
How about honeycomb type of a core. The doors would be lighter, flatter and very strong. It would basically be a torsion door.
-- Oldworld, Fair Oaks, Ca
