1977 Rockwell 14" 28-200
Forum topic by Will Merrit posted 01-30-2016 02:54 AM 3081 views 1 time favorited 40 replies Add to Favorites Watch
View Will Merrit's profile
Will Merrit
87 posts in 1013 days
01-30-2016 02:54 AM
Topic tags/keywords: bandsaw rockwell
Well I scored this at a auction for $180.00. Fixing to start cleaning up and tuning in. Any one have any special reccomendactions on what I should do to her while she is torn down? Anyone ever built their own riser block? Welp I appreciate all the help I can get…here goes
40 replies so far
View conifur's profile
conifur
955 posts in 1271 days
#1 posted 01-30-2016 03:12 AM
Nice!!! I am not a metal man, but to make a riser block out of wood I dont think it could handle the tension. I have read here, I think the Grizzly will work, but let some one confirm that.
runswithscissors
2821 posts in 2144 days
#2 posted 01-30-2016 04:36 AM
I fortunately live near both an aluminum smelter and a metal recylcler, so I can get big blocks of AL by the pound. I actually have such a block if I ever need to raise mine a couple of inches (18” saw with only 10” over the table), and I figure it will work well for that.
View MrUnix's profile
MrUnix
6889 posts in 2318 days
#3 posted 01-30-2016 05:02 AM
Start by tearing it apart, then clean and paint:
Get some new bearings, belts, tires and a good blade, and then put it back together agian so it looks all purdy :)
After that, tune it up and start making sawdust.
Here is the obligatory band saw tune up video:
Band Saw Clinic with Alex Snodgrass
Will Merrit
#4 posted 01-30-2016 07:29 AM
Brad,
I have seen that picture before and whoever did that really set the bar high. I got a littlemail bit done this evening. I took it off the base trashed the belt and tires and started taking apart and cleaning. I am amazed at how many parts there are but even more impressed with how many cast parts there are! I hit the whole saw with a wire wheel brush and that took care of surface rust and chipped paint. On to the stand tomorrow I reckon. I do have a few questions though.
1. I couldn’t figure out how to remove the lower wheel. Do you have to use a puller?
2. Would I be ostracized and kicked off of here if I painted over all the previously painted surfaceS with back bed liner paint?
4. Dear Lord I can put this all back together! Any good resources you know on these saws would help a lot.
Night
MrUnix
#5 posted 01-30-2016 07:51 AM
- Will Merrit
What happened to #3?? [insert evil-grin here]
1) No. Take off the nut and it comes right off. There is a key in there and sometimes the wheel can be a little stubborn, but some gentle force and maybe a couple taps with a rubber mallet in strategic locations should get it off. Just go easy on it as you don’t want to bend or break anything.
2) Nope – It’s your saw… paint it however you want (but please don’t make it pink!)
4) The parts diagram in the manual is your best guide. And take lots of pictures along the way so you can go back and check how things went if you get stuck. There aren’t really that many parts involved… at least not compared to some machines, and it’s pretty simple to figure out.
PS: It’s my saw in that picture :-)
View SirIrb's profile
SirIrb
1239 posts in 1350 days
#6 posted 01-30-2016 07:54 AM
PICTURES PICTURES PICTURES!!! You have to take pictures as you tear it down.
Brad, I have seen that picture before and whoever did that really set the bar high. I got a littlemail bit done this evening. I took it off the base trashed the belt and tires and started taking apart and cleaning. I am amazed at how many parts there are but even more impressed with how many cast parts there are! I hit the whole saw with a wire wheel brush and that took care of surface rust and chipped paint. On to the stand tomorrow I reckon. I do have a few questions though.
1. I couldn t figure out how to remove the lower wheel. Do you have to use a puller?
Night
- Will Merrit
View onoitsmatt's profile
onoitsmatt
394 posts in 1295 days
#7 posted 01-30-2016 02:32 PM
Hi Will. Cool saw. I blogged a pretty full restoration of my 1950s Delta Band Saw here:
http://lumberjocks.com/onoitsmatt/blog/64834
This is part 1 of 6. Each part tackles a different set of components.
I couldn’t find a one-stop resource for a beginner like me that fielded all the dumb questions I had. So I learned and blogged and learned some more.
It is a great way to learn about the machine.
I have more photos if you need to see how something fits together. I tried to include pretty comprehensive photos of each component in the blog. Just PM or ask here.
-- Matt - Phoenix, AZ
Will Merrit
#8 posted 01-30-2016 02:51 PM
Matt
Thanks a million. I will be using this!
Will Merrit
#9 posted 01-31-2016 04:32 AM
Matt and Brad
I have a issue. I have taken the lower pull your and nut off. I have also take off the nut off off the wheel side but I cannot get the wheel off of the shafts. I accidently tried to drive the woodruff key inwards toward the body, and now I cannot remove the wheel from the shaft. I have put a puller on there with no success I cannot figure it outo. The bearing seems good here is the question
1. Leave it be and run with the old bearing or .
2. Keep working till I get two wheels off?
3. Does the key come out on the lower wheel assemby before you can pull the tite?
MrUnix
#10 posted 01-31-2016 04:42 AM
No on 1, yes on 2.
Once you take the nut off the wheel side, the wheel comes off. Not always easily though :) Usually a little cleaning up, some penetrating oil and gentle persuasion is all that is needed. As an alternative, you can remove the lower drive shaft with the wheel still in place. Tap the shaft out from the rear towards the front. Make sure you have removed the pulley, key and nut on the back first. Not sure what you are asking about in #3, but AFAIK, the key can’t be removed before taking off the wheel.
Will Merrit
#11 posted 01-31-2016 12:30 PM
I have tried it all and the blasted tire won’t come off. I even put a puller on it but gave up because I am scared it will bend the tire. I think I messed up without thinking I drove the key holding the tire on further in towards the bearing. My only option at the point is to cut the bearing off and drive the key back out. Thoughts?
onoitsmatt
#12 posted 01-31-2016 02:00 PM
Ditto to what Brad said. I don’t think the key is a problem. It is a semicircle, rounded on the bottom. It won’t cause the wheel to get stuck. Gear puller should work if you have removed the nut. Or tapping the shaft may help. You may want to disassemble the pulley side first or do the top wheel to get more familiar.
View TheWoodRaccoon's profile
TheWoodRaccoon
364 posts in 1049 days
#13 posted 01-31-2016 02:08 PM
I have tried it all and the blasted tire won t come off. I even put a puller on it but gave up because I am scared it will bend the tire. I think I messed up without thinking I drove the key holding the tire on further in towards the bearing. My only option at the point is to cut the bearing off and drive the key back out. Thoughts?
- Will Merrit
Just keep in mind, the “tire” is the rubber or urethane strip that covers the outer circumference of the wheel. What you’re referring to is the “wheel”, just clearing up any confusion.
As for the your issue:
On the bottom wheel, there are bearings that are encased by the lower half of the cast iron frame, and there is a shaft that protrudes from both sides. One side has the wheel on it, the other has a pulley. If the “wheel” is still on the shaft, how do you plan on cutting the bearing off? The bearings are behind the wheel, not in the wheel like on the top wheel. Do you mean the shaft? DO NOT cut the shaft, or anything for that matter…..Just keep hitting it with WD-40. If not, gently heat the wheel itself with a propane torch and a circular motion around the hub close the shaft, and use the puller. That should work. Just keep at it, however long it takes, and it will eventually come off.
-- still trying to think of a clever signature......
TheWoodRaccoon
#14 posted 01-31-2016 02:13 PM
Post some pictures of what you are doing and how you are doing it, it might help us help you!
TheWoodRaccoon
#15 posted 01-31-2016 02:16 PM
Ill go down to my bandsaw and do a little demontration video to help you out, ill post it ASAP!
showing 1 through 15 of 40 replies
