Cutting Kreg Top Track Components
Forum topic by EdsCustomWoodCrafts posted 01-30-2016 02:53 AM 1056 views 0 times favorited 6 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
782 posts in 1365 days
01-30-2016 02:53 AM
I am wondering can I cut this Kreg Top Track to size with a regular mitre saw 10” 60 tooth blade.. I don’t have a hacksaw and really just don’t want to buy one and since I just bought this new craftsman mitre saw I want to use it to cut and also anytime I have cut aluminum before with a hack saw its been less than perfect and I want a seem less transition between the joint lines of the track.. These tracks are very exspensive and only have one shot at this and I figured I ask the LJ’s
Thanks guys
Ed
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
View RobS888's profile
RobS888
2412 posts in 1867 days
#1 posted 01-30-2016 04:08 AM
Usually aluminum is fine, push a little slower.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
runswithscissors
2762 posts in 2047 days
#2 posted 01-30-2016 04:29 AM
I cut aluminum often with my miter saw. Wear a face shield, or at least eye protection. And don’t wear fleece, as the chips stick in fleece like burrs. Tho actually, the saw should shoot the chips away from you. As Rob says, cut slowly.
runswithscissors
#3 posted 01-30-2016 04:32 AM
P. S. With a small cut like that, there shouldn’t be a problem with the AL sticking to the teeth, but I you are making significant cuts, such as a ripping cut on a TS, WD 40 will help with that. Aluminum is very sticky, and you sometimes have to stop and knock the chips off the carbide, which doesn’t cut well when loaded up.
EdsCustomWoodCrafts
#4 posted 01-30-2016 04:35 AM
I have a older 40 tooth blade should I just use that instead of ruining a better newer blade
Thanks Guys
runswithscissors
#5 posted 01-30-2016 08:29 AM
You won’t ruin a carbide blade, as long as you take it easy. Let the saw get up to full rpm before making the cut.
View builtinbkyn's profile
builtinbkyn
2359 posts in 962 days
#6 posted 01-30-2016 02:22 PM
Very easy to cut Al. Make a zero clearance miter jig for it. The cuts will be much cleaner. The jig is also very important if you’ll be taking small pieces from the end. The piece won’t fly off and won’t bend in instead of severing.
-- Bill, Yo!......in Brooklyn & Steel City :)
