Adhesives-Gorilla Glue-Do you use it?
« back to Joinery forum
Forum topic by tturner posted 01-29-2016 02:05 PM 889 views 0 times favorited 14 replies Add to Favorites Watch
View tturner's profile
tturner
63 posts in 1996 days
01-29-2016 02:05 PM
Topic tags/keywords: question clamp biscuit joiner glue adhesive titebond
There is no one adhesive that is good for all uses. My go-to glue is Titebond III but there are times when I feel it may not be good enough. I have come to use Gorilla Glue. Lets face it, the name alone can attract us to us it, their duct tape and a few of their other products. I have to say that if you follow the 3 directions, 1-wet it, 2-spread it, 3-clamp it, its a very very strong bond. I tend to use it on larger stuff such as wider than 2 inch joints, such as gluing up a wide slab. Its messy, it doest come off of anything easily, but so far, it looks like a great heavy-duty adhesive.
What are your thoughts and experiences?
-- I'm him
14 replies so far
View jdh122's profile
jdh122
995 posts in 2785 days
#1 posted 01-29-2016 02:50 PM
I frequently use their regular wood glue, seems to work as well as any other yellow glue. I’ve tried their polyurethane glue and didn’t like it at all. The mess was terrible and hard to deal with. And just about every test I’ve read of glues puts it dead last in terms of strength, especially when it comes to gap-filling in less than perfect joints. In a FWW article from 2007, the strength of GG was only 58% of that of regular yellow glue in well-fitting joints, and about a third as strong in loose-fitting joints!
The only real advantage to me is the superior waterproofness, but there are few applications where Titebond III isn’t waterproof enough.
-- Jeremy, in the Acadian forests
View rick1955's profile
rick1955
264 posts in 1398 days
#2 posted 01-29-2016 02:50 PM
Tight bond makes a polyurethane adhesive as well. There are less foaming ones out there.
-- Working smarter with less tools is a true crafts person...
View Bill White's profile
Bill White
4907 posts in 3928 days
#3 posted 01-29-2016 02:55 PM
If ya want to glue a bunch of rock together, it is great. Other than that, I’ve found no real application for it.
Bill
-- bill@magraphics.us
View bigblockyeti's profile
bigblockyeti
5096 posts in 1688 days
#4 posted 01-29-2016 02:59 PM
I use it sometimes, the mess is the biggest detractor for me. If you’re not wearing gloves and you get it on your hands it takes forever to come off. The shelf life doesn’t seem that great either.
View RootandBranch's profile
RootandBranch
241 posts in 1072 days
#5 posted 01-29-2016 03:05 PM
Not anymore. The mess just wasn’t worth it to me.
-- Don, https://www.etsy.com/shop/RootandBranchGifts - http://facebook.com/rootandbranchgifts
View SuperCubber's profile
SuperCubber
1023 posts in 2252 days
#6 posted 01-29-2016 03:51 PM
From a Wood Magazine glue test:
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View JAAune's profile
JAAune
1788 posts in 2284 days
#7 posted 01-29-2016 04:00 PM
I always keep a bottle of it around. It’s excellent for any application where water is an issue. I use it for some veneer work if I don’t want water messing with the veneers while they’re being pressed (complex decorative assemblies for example).
4954 posts in 2461 days
#8 posted 01-29-2016 06:07 PM
I’ve tried a couple of bottle of it…just doesn’t seem to have any use for the woodworking I do. As somone else mentioned, the mess alone makes it not worthwhile.
View Nezzerscape's profile
Nezzerscape
30 posts in 831 days
#9 posted 01-29-2016 06:21 PM
I tried it once or twice and ended up tossing it for the reasons above. Thought this was a nice test video
View Jim Finn's profile
Jim Finn
2647 posts in 2889 days
#10 posted 01-30-2016 03:49 AM
I also, do no longer use it. Titebond or even white glue is stronger than most wood.
-- Website is https://craftingcouple.com/
View BurlyBob's profile
BurlyBob
5411 posts in 2233 days
#11 posted 01-30-2016 03:58 AM
It’s a once in a blue moon product for me. If I wanted a really strong waterproof glue I’d opt for that plastic resin powder glue that Dap now sells. It says to mix it with cold water but I’ve found that hot tap water works quite well.
It’s only draw back is a really short work time. But Holy crap, once it sets it’s like a solid weld. It’s got it’s specific place in the world like so many other things. I keep a can on my shelf just for that specific place.
runswithscissors
2725 posts in 1993 days
#12 posted 01-30-2016 04:34 AM
I only use it when I have to glue gorillas, which isn’t often. I wonder if it would have restrained King Kong?
woodbutcherbynight
4348 posts in 2376 days
#13 posted 01-30-2016 04:35 AM
I have tried it but found it has poor shelf life verses TITEBOND wood glue which for me has done very well. The shop will cut on the heat if it falls below 45F and it does not generally exceed 100F.
View REO's profile
REO
928 posts in 2042 days
#14 posted 01-30-2016 01:53 PM
I do large turnings. for years the best adhesive for exterior work was rescorcinal (sp) THAT was messy and had a short pot life. switched to a Poly product many years ago and haven’t gone back. Water is used in the curing process rather than removing water. rather than wet the surface of the wood try using a spray bottle when the parts have been coated, mist just before assembly. wear gloves it can cause sensitivity. for storage especially in humid climbs expel access air from the container and cap. the humidity in the air drawn in during use is what cases it to chunk up in the bottle on the shelf. I work at a company that deals exclusively in veneered products. although the industry standard in the past has been PVA the movement is toward Poly adhesives.
http://navyisland.com/who-we-are/factory-tour.html
