How do you fix a ding?
Forum topic by ClammyBallz posted 01-28-2016 07:42 PM 619 views 0 times favorited 3 replies Add to Favorites Watch
View ClammyBallz's profile
ClammyBallz
435 posts in 1158 days
01-28-2016 07:42 PM
Just my luck, I was putting the doors on this cabinet after I finished spraying it and put a ding on the trim. Other than sanding & refinishing, are there any other options to fix this? It’s cherry coated with garnet shellac and target coatings conversion varnish.
3 replies so far
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1236 days
#1 posted 01-28-2016 08:53 PM
Looks like you dented the wood under the finish. Luckily you can re inflate that dent with a hot iron and a wet towel. But the finish it probably, finished. Sand or scrape the affected area and refinish.
-- Talent, brilliance, and humility are my virtues.
View Woodknack's profile
Woodknack
11758 posts in 2401 days
#2 posted 01-29-2016 04:52 AM
+1, what he said.
View oldnovice's profile
oldnovice
6894 posts in 3389 days
#3 posted 01-29-2016 06:50 AM
Yes, I have used the same method described above and it works like a charm.
If the piece is small enough I hold it over a boiling tea kettle.
Unfortunately most finishes do not survive.
