Best saw set for a champion tooth crosscut saw
« back to Hand Tools forum
Forum topic by giser3546 posted 01-27-2016 05:59 PM 901 views 0 times favorited 4 replies Add to Favorites Watch
View giser3546's profile
giser3546
179 posts in 1648 days
01-27-2016 05:59 PM
I am looking for a saw set for my crosscut saw. Many I have seen seem to be intended for a given TPI range and the lowest I have seen is 4 TPI. Where would Champion tooth fall on the TPI scale and which saw set would be best?
-- "If you wait for it to rain, It will"
View James Wright's profile
James Wright
331 posts in 1039 days
#1 posted 01-27-2016 07:59 PM
When you go larger tooth then 4TPI you usually want to use hammer and anvil.
-- James Wright, Rockford IL, https://www.youtube.com/c/WoodWright
View Tim's profile
Tim
3812 posts in 2137 days
#2 posted 01-28-2016 12:31 AM
You can use a saw wrest too. I have a Stanley 43 saw set that says it is designed for crosscut saws and two man saws having 5 or less teeth per inch. I’ve never used it though.
In the videos posted in your other thread it shows how to do the hammer and anvil method I believe.
giser3546
#3 posted 01-28-2016 01:55 AM
Thanks Tim. I’ll look into the 43.
View ATSawyer's profile
ATSawyer
14 posts in 3613 days
#4 posted 01-28-2016 05:20 PM
The only grip set I have ever used on a crosscut saw is this one, demonstrated by Jim Thode on crosscutsawyer.com
It’s a beast and ones like it pop up on Ebay from time to time.
http://www.crosscutsawyer.com/viewtopic.php?f=21&t=1076&hilit=apex&start=10#p5350
-- Dan
