Before attaching Unisaw table top, anti-vibration washers or such?
Forum topic by Holbs posted 01-27-2016 01:08 AM 1658 views 0 times favorited 39 replies Add to Favorites Watch
View Holbs's profile
Holbs
1864 posts in 2025 days
01-27-2016 01:08 AM
Topic tags/keywords: unisaw anti-vibration rubber washers high frequency
I am to the point on my tear down / rebuild 1997 Delta Unisaw: new arbor & motor bearings, general cleanup of all metal. I was thinking today, would anti-vibration or rubber washers help/hinder/make no difference when it comes time to attached the cast iron top? Without the cast iron table top, it would not pass the nickel test but I think that is because there is no cast iron top attached :) I am just thinking of ways to help vibration / high frequency stuff before final assembly.
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
39 replies so far
View MrUnix's profile
MrUnix
6704 posts in 2195 days
#1 posted 01-27-2016 01:15 AM
I wouldn’t do anything to it other than put it back the way it was.
View TheWoodRaccoon's profile
TheWoodRaccoon
364 posts in 925 days
#2 posted 01-27-2016 12:40 PM
I agree. Put it back the way it was, and then try the nickel test again! All that heavy cast iron will surely help.
-- still trying to think of a clever signature......
View Ger21's profile
Ger21
1074 posts in 3127 days
#3 posted 01-27-2016 12:53 PM
Is it sitting level on the floor where it can’t move at all?
A Unisaw should not be vibrating when running without a blade on it.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View SirIrb's profile
SirIrb
1239 posts in 1226 days
#4 posted 01-27-2016 12:57 PM
Dont do that. It could make the table unlevel to the trunion. This matters when you are cutting anything that is not 90 degrees. If the table is lower in the back the blade will not make a true cut is you are cutting on 45 degrees, for example.
View bigblockyeti's profile
bigblockyeti
5112 posts in 1716 days
#5 posted 01-27-2016 01:04 PM
As others have stated, don’t do it. If it’s vibrating, first take the belts off then try it again to eliminate the motor as a culprit. If it’s vibrating with the belts and no blade and doesn’t vibrate without them, the belts have most likely taken a set and the saw just needs to be run more often. Fire it up and let it run for ten to fifteen minutes and see if it’s smoother after the belts have a little heat in them.
4984 posts in 2489 days
#6 posted 01-27-2016 01:17 PM
One more time: put it back the way it was.
View CharleyL's profile
CharleyL
222 posts in 3360 days
#7 posted 01-27-2016 02:25 PM
Not only “don’t do that”, but I hope you kept track of where the shims were located so you can put them back in the same places. When these saws were built they inserted shims between the cabinet and the table to level that table to that base. No two Unisaws had the shims the same thickness or in the same places. If you didn’t keep track of them you are going to spend a whole lot of time getting the table bolted down tight and flat again.
The cast iron top will make a big difference in reducing vibration. Link belts will also help. V belts take a set when not used becoming ovals instead of circles. The link belts don’t do this.
Charley
View TheFridge's profile
TheFridge
9446 posts in 1482 days
#8 posted 01-27-2016 02:30 PM
I had to shift the factory set in my belts 120 degrees apart and run it a bit
Does it run smooth without the belts on?
Holbs
#9 posted 01-27-2016 04:42 PM
OK. No anti vibration washers. I’ll be assembling the top this Wed or Thurs and see how, if any, vibration exists then troubleshoot the cause. L
TheFridge
#10 posted 01-27-2016 04:59 PM
It wouldn’t pass the nickel test because it jumps on startup or vibration after startup?
SirIrb
#11 posted 01-27-2016 05:33 PM
I disagree with the link belt comment. The existence of the links makes each time a link passes over the pulley a place for it to bump. They have also shown to wear the pulley more than a belt that fits the V of the pulley. A segmented V belt is a good option. Or just a V belt. Once run in it should not pose any problems.
Not only “don t do that”, but I hope you kept track of where the shims were located so you can put them back in the same places. When these saws were built they inserted shims between the cabinet and the table to level that table to that base. No two Unisaws had the shims the same thickness or in the same places. If you didn t keep track of them you are going to spend a whole lot of time getting the table bolted down tight and flat again.
The cast iron top will make a big difference in reducing vibration. Link belts will also help. V belts take a set when not used becoming ovals instead of circles. The link belts don t do this.
Charley
- CharleyL
TheWoodRaccoon
#12 posted 01-27-2016 06:40 PM
It wouldn t pass the nickel test because it jumps on startup or vibration after startup?
- TheFridge
I was gonna ask the same thing!
View AlaskaGuy's profile
AlaskaGuy
4127 posts in 2305 days
#13 posted 01-27-2016 07:42 PM
Agree with those who say “put it back the way it was” hopefully you keep track of which washers were on which bolts on the table top. They need to go back exactly where they were.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2106 days
#14 posted 01-27-2016 09:10 PM
Belts often take a set if the tool sits for a bit.
My old saw, a General 650 often took a good 15-20 minutes of running to get smooth again if I didn’t use it for a week or two. As the others said, the top will help and don’t fix something that isn’t broken by adding parts.
MrUnix
#15 posted 01-27-2016 09:37 PM
Check your belt tension. They need to be set a lot looser than you might think. Too much tension (or too little tension) will let the belts slap a bit, creating a slight vibration if bad enough. Put the top on and see how it runs and watch the belts. I found the easiest way to get that ‘sweet spot’ is to adjust the belt tension with the machine running, so you can watch the belts in action.
PS: Don’t waste your money on link belts – they don’t give you any benefit on a multi-belt setup. And on the older Unisaws, they will actually damage the pulleys.
showing 1 through 15 of 39 replies
