Motor to upgrade bandsaw.
Forum topic by dbhost posted 02-02-2010 05:08 PM 5075 views 1 time favorited 6 replies Add to Favorites Watch
View dbhost's profile
dbhost
5767 posts in 3474 days
02-02-2010 05:08 PM
Topic tags/keywords: question
Now there is nothing wrong with my band saw, but I do have a project I would like to use its 1HP motor for. Specifically a wide drum sander, and thought this would be a good time to upgrade the band saw to a 1.5HP motor.
Only problem is, I am not sure what to look for in an electric motor for a band saw. Can you guys or gals give me any decent pointers?
I need to keep the budget in mind, so I can only consider motors under $200.00, the lower the better, but I do not want junk either…
I have a Dayton 1.5HP motor in the attic that a friend gave me, I hooked it up and it is dead… is that worth trying to get it fixed?
View Jim Bertelson's profile
Jim Bertelson
4256 posts in 3406 days
#1 posted 02-02-2010 05:33 PM
I don’t know anything about motors. I wonder if there are some straight forward tests with VOM that would tell you where it might have problems. I would guess the Dayton could be run on 110 or 220, so it might be worth investing a little time into it to be sure it doesn’t have a simple problem.
-- Jim, Anchorage Alaska
View Steve Peterson's profile
Steve Peterson
395 posts in 3324 days
#2 posted 02-02-2010 06:20 PM
The most important parameter is to match the RPMs. Many bandsaws are 1725 RPM. Motors commonly come in 3450 RPM and 1725 RPM, with the 3450 RPM seeming to be the most popular (smaller and cheaper also).
The next criteria is mounting. There are 2 styles, side bracket mount (56 frame) or face mount (56C frame). Pick the one that matches and start searching. Look up the model number of the motor currently on the bandsaw and you should be able to identify the mounting size. All 56 frame motors should be compatible with each other.
One more criteria is cooling. The existing motor is probably TEFC (totally enclosed fan cooling). Match the same type.
One final parameter is voltage. A 1 HP motor would run just fine on 110V. 1.5 HP would be running around 15A (maybe more) on 110V. It should be on it’s own breaker, preferably 20A. Or even better wire it for 220V.
There are many web sites that sell motors that let you search by parameters to find exactly what you want. An import quality 1.5 HP motor should run around $150. A Leeson or a Baldor would probably be about $300.
-- Steve
View ChunkyC's profile
ChunkyC
856 posts in 3496 days
#3 posted 02-03-2010 02:21 AM
is that worth trying to get it fixed? No. It’s a lot cheaper to buy a new one for a single phase, 110 / 220 Vac motor. I doubt that you could even find a motor shop to repair it. You can try checking the starting capacitor, that might be all that’s wrong with it.
Go to grainger.com, they have a motor “configurator” that you can use to help select the correct motor. I put a 3 phase 240V VFD rated motor on my drill press for, if I remember correctly, less than $200.
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
117423 posts in 3819 days
#4 posted 02-03-2010 02:27 AM
How about The company that made your saw or Grizzly they may have and upgrade.
View Julian's profile
Julian
880 posts in 3767 days
#5 posted 02-03-2010 03:48 AM
I scored an oldie but a goodie made in wisconsin 1 1/2 hp motor for my rigid 14” bandsaw off of craigslist for under $100. It’s not a tefc motor so I just keep the shroud clean. With the larger motor and a 6” riser block my saw cuts through 12” thick mahogany and oak much better than the stock 3/4 hp motor could.
-- Julian, Park Forest, IL
View davidroberts's profile
davidroberts
1027 posts in 3727 days
#6 posted 02-28-2010 06:42 PM
i ran across this blog while looking for your HF detensioner upgrade blog. Regarding your electric motor, if you’re are still interested in using it, try looking at the capacitor. More times than not, its the capacitor. It lives under than bump on the side of your motor. They are an easy cheap replacement fix. You may want to look at the wiring and connections, depending on the age. Just a thought. I’ll go back to looking for your detensioner blog.
-- Better woodworking through old hand tools.
