joist size ???
Forum topic by dustycajun posted 01-26-2016 06:41 PM 659 views 0 times favorited 7 replies Add to Favorites Watch
View dustycajun's profile
dustycajun
71 posts in 1483 days
01-26-2016 06:41 PM
I am building a lean to, 12 foot wide , need suggestions on joist for roof , should i use 2×6 or would 2×8 be
Better. Im using a metal roof.
-- klcrd
7 replies so far
View jusfine's profile
jusfine
2422 posts in 2924 days
#1 posted 01-26-2016 07:05 PM
Is 12’ the clear span from building to your beam?
It would also depend on the slope, if it is a low slope (3 or less), I would go 2×8. If more, 2×6 should be fine.
In Canada we have to consider snow load, doesn’t look by your location like that is an issue…
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View bigblockyeti's profile
bigblockyeti
5120 posts in 1719 days
#2 posted 01-26-2016 07:10 PM
Houma isn’t likely to see too much snow any time soon so 2×6 would work, the steeper the pitch the better (within reason). I would personally still prefer to use 2×8 for the joists just for greater strength.
Smitty_Cabinetshop
15353 posts in 2617 days
#3 posted 01-26-2016 07:12 PM
Rule of thumb: distance divided by two is dimension lumber need, rounding up in every case. 12’ means 2×6 is minimum. Metal roof lightweight. I’d say it’s fine. Consult building codes, etc. as necessary.
View MrUnix's profile
MrUnix
6714 posts in 2197 days
#4 posted 01-26-2016 07:14 PM
Depends on the load. I used 2×6 (actually, I just ripped a 2×12 in half) on a 14 foot span for my pole barn, but it’s a pretty light roof and we don’t need to worry too much about snow down here in Florida :)
I don’t think going bigger would hurt, but going smaller might!
View bondogaposis's profile
bondogaposis
4727 posts in 2350 days
#5 posted 01-26-2016 07:16 PM
What is your snow load? Here it is 34 lbs/sqft. Okay, I take that back I see you are in LA. My guess 2×6 will adequate.
-- Bondo Gaposis
View conifur's profile
conifur
955 posts in 1150 days
#6 posted 01-26-2016 07:50 PM
Also consider the distance between each one. 16 or 24 on center? That also needs to be factored in.
View dhazelton's profile
dhazelton
2767 posts in 2295 days
#7 posted 01-26-2016 08:34 PM
12 wide but how deep? Run your joists the short way and you could get by with smaller lumber.
