Sorting the Output for Cut List when Compact List is selected
Forum topic by svzephyr posted 02-02-2010 03:58 PM 783 views 0 times favorited 1 reply Add to Favorites Watch
View svzephyr's profile
svzephyr
6 posts in 3086 days
02-02-2010 03:58 PM
Topic tags/keywords: cutlist cut list
Hi,
I’ve switched from CutList 3 to CutList 4 (both are awesome!), and I generally use the Compact List option for output. In CutList 3 the web output was sorted by component name. In CutList 4 the web output is listed by component ID – C-1, C-2, C-3. Is there a way to sort by name when Compact is selected?
I tried adding these lines of code just before the def output section, but the list still didn’t sort.
if @@options[:cutlist_Options][:compactList]
@solidPartList.sort
@sheetPartList.sort
end
It’s mainly the web output that I’d like to see sorted (for file output I can easily sort in Excel) – I used to use the web option to quickly find and correct component naming problems in a large sketchup model before outputting to the .csv file.
Thanks,
-- Lynn, Louisville, KY, USA
1 reply so far
117127 posts in 3605 days
#1 posted 02-08-2010 01:34 AM
Interesting
