tablesaw not working
Forum topic by roughcutter83 posted 01-26-2016 04:52 PM 671 views 0 times favorited 7 replies Add to Favorites Watch
View roughcutter83's profile
roughcutter83
5 posts in 724 days
01-26-2016 04:52 PM
Topic tags/keywords: tablesaw motor
I have a old craftsman table saw it is not belt driven. When i plug it in it locks up, the saw spins freely when unpluged. I have tried giving it a rolling start, but it just locks down as soon as the power hits it. The saw was a gift from my grandpa mainly becuase he got tired of me take off with his. Any help would be greatly appreciated. Also when i got the saw it was completely unwired.
7 replies so far
View MrUnix's profile
MrUnix
6191 posts in 2071 days
#1 posted 01-26-2016 04:58 PM
Sure would help if you could let us know exactly what saw it is that you have.
PS: since you mention it was ‘unwired’, that throws up a couple of red flags based on your description of it ‘locking’ when power is applied. Are you sure you wired it correctly? Post some pictures.
View TheFridge's profile
TheFridge
8656 posts in 1358 days
#2 posted 01-26-2016 05:00 PM
If it’s an older craftsman contractor I’d say it’s probably the start capacitor or centrifugal switch.
View 716's profile
716
502 posts in 788 days
#3 posted 01-26-2016 06:19 PM
If it s an older craftsman contractor I d say it s probably the start capacitor or centrifugal switch.
- TheFridge
He says the “rolling start” does not help. I personally would not do it for safety reasons but that would indicate that it is something besides the capacitor ( if this is an induction motor at all ). Could be for example destroyed ballbearings.
-- It's nice!
roughcutter83
5 posts in 724 days
#4 posted 01-26-2016 09:30 PM
Thanks for yhe help guys i will find out what kind of saw it is maybe post a pic or two the wiring was a little burnt and did not have a starting compacitor on it doesnt mean it shouldnt have one though
View MadMark's profile
MadMark
979 posts in 1325 days
#5 posted 01-27-2016 01:05 AM
Wires burnt?
Sounds like there’s the issue!
Reverse one winding & see if it spins …
M
MrUnix
#6 posted 01-27-2016 01:20 AM
Direct drive and no capacitor sounds like one of those portable universal motor things. If so, it’s most likely the rear bearing housing that has warped/distorted (the motor housing is plastic). With enough play, it can allow the armature to come into contact with the windings or under power, pull it enough to bind the bearings. If that is it, there isn’t much you can do other than replace it… or turn it into a router table :)
roughcutter83
5 posts in 724 days
#7 posted 01-28-2016 03:57 AM
Thanks for all the help guys havent had a chance to work on it i will tomorrow morning.
