#80 scraper
Forum topic by MNWOODWORKER posted 02-02-2010 07:29 AM 1016 views 1 time favorited 6 replies Add to Favorites Watch
View MNWOODWORKER's profile
MNWOODWORKER
105 posts in 3549 days
02-02-2010 07:29 AM
I just goet a heck of a deal on a sweetheart #80, $8. The only thing is that it has no blade. I have a number of scrapers, one that I have is pretty thick and I don’t like using it because it is too hard to flex so I figured I would use that unless anyone has any other ideas. What angle do you guys and gals bevel yours to?? I was planning on starting at about a 45 degree angle, and tuning just like any other scraper and going from there, any suggestions would be great. I have been using scrapers confidently for a long time but never like this. Thanks a bunch and look forward to hearing from you.
117061 posts in 3541 days
#1 posted 02-02-2010 07:34 AM
here’s a link on scrapers
http://www.youtube.com/watch?v=OAYST--mtNo
View knotscott's profile
knotscott
7980 posts in 3339 days
#2 posted 02-02-2010 03:15 PM
Thanks for the link Jim! I’ve got a #80 that I’ve never bothered to master…this should help!
View WayneC's profile
WayneC
13753 posts in 4061 days
#3 posted 03-03-2010 07:16 AM
Were you able to find a blade?
MNWOODWORKER
#4 posted 03-03-2010 08:55 PM
I took a regular scraper that I had and cut it down, beveled it toa 45 degree angle and rolled a nice burr on it, but I have a lot of chatter. When I tuned the #80 itself I made sure that the surface that the scraper sits against is perfectly smooth and not being hung up on a casting ridge or anything, I wonder if the scraper I am using is just too thin?? I had a few and one of them was too thick to use and comfortably flex by hand so I thought it would be perfect for in the #80. Any suggestions would be great.
Thanks again
Nate
View Ingjr's profile
Ingjr
144 posts in 2980 days
#5 posted 03-03-2010 10:34 PM
Sounds like the cut is too deep to me. I have a #80 also and it does the same thing if I have too deep of a cut. HTH.
-- The older I get the faster I was.
WayneC
#6 posted 03-04-2010 12:28 AM
I was just going to provide a couple of sources for replacement blades.
http://www.highlandwoodworking.com/stanleyno80scraperreplacementblade.aspx
http://www.hocktools.com/SB.htm
I would check with Brian Havens for advise if you do not get past it.
http://lumberjocks.com/brianhavens
