Spindle per Step Help
Forum topic by rhym1n posted 01-26-2016 04:50 PM 576 views 0 times favorited 2 replies Add to Favorites Watch
View rhym1n's profile
rhym1n
6 posts in 1090 days
01-26-2016 04:50 PM
Hello,
I am replacing the carpet on my stairs and hallway, and also the spindles, newels, and railing. I am wondering if anyone has any recommendations on spindle placement as far as the stairs go. I believe the code is no more than 4” apart, but I’m trying to use 2 spindles per step instead of 3 as they are a bit pricey (I’m using oil rubbed copper spindles).
Here are the measurements:
Spindles are exactly 1/2” wide.
Each step is 10.5” deep, and there are 6 steps.
I would like the spindles to be evenly spaced throughout the 6 steps, but good Lord, I am horrible at math. Lol.
Any help is greatly appreciated.
2 replies so far
View HokieKen's profile (online now)
HokieKen
7568 posts in 1377 days
#1 posted 01-26-2016 07:38 PM
2-5/8” back from the front of each step then space 5-1/4” on centers. That will give you 2 spindles/step with even spacing through all 6 steps. That’s not to code and if you ever sell your house, the Home Inspector will catch it and you will likely end up re-doing it. If you want to do it to code, start 1-3/4” back from front of each step and then space them on 3-1/2” centers. That’ll give you 3 spindles/step and keep your spacing < 4”.
-- Kenny, SW VA, Go Hokies!!!
rhym1n
#2 posted 01-26-2016 07:56 PM
I’ll definitely want to be up to code, so I’ll just go with 3 spindles per step. It will just cost a little more. Thank you very much for the info!
