Recess tenon
« back to Woodturning forum
Forum topic by jeff posted 01-26-2016 09:48 AM 706 views 0 times favorited 3 replies Add to Favorites Watch
View jeff's profile
jeff
1081 posts in 3493 days
01-26-2016 09:48 AM
I have a Nova G3 chuck with the standard 50mm jaws.How much depth in a recess tenon is needed if I want to try turning a project this way?.
-- Jeff,Tucson,Az.
3 replies so far
View LeeMills's profile
LeeMills
550 posts in 1329 days
#1 posted 01-26-2016 12:01 PM
From http://www.teknatool.com/products/Chucks/SuperNova2/Downloads/SuperNova2%20Maunal%20full%20version.pdf
”The larger bowl blanks or softer woods will require a deeper recess up to the maximum of 6mm (1/4 inch). Page12
HOWEVER YOU MUST USE THE MAXIMUM RECESS DEPTH ON ALL RECESSES OVER
64mm (2.5 inches) diameter OR ANY WORK WITH A DIAMETER OVER 150mm (6 inches).
For smaller lids and thin platters (not exceeding 150mm diameter) only a shallow recess of
around 3mm (1/8 inch) is necessary. It will be a matter of gaining experience as to what
combinations and sizes will suit best.”
I go with the max (1/4”) on most everything except platters where depth matters (wood conservation).
View Nubsnstubs's profile
Nubsnstubs
1299 posts in 1758 days
#2 posted 01-26-2016 02:42 PM
Jeff, why don’t you make a trip out to the Southwest side off Valencia, and I’ll show you what I’ve been doing and how I do it…........ PM me with a phone number if you think it’s a good idea…...... Jerry (in Tucson)
View jeff's profile
jeff
#3 posted 01-26-2016 03:28 PM
LeeMills thank you for the info…Jerry I will send you a PM and thanks.
-- Jeff,Tucson,Az.
