v-notches
Forum topic by jay_in_cgohio posted 01-26-2016 12:53 AM 702 views 0 times favorited 6 replies Add to Favorites Watch
View jay_in_cgohio's profile
jay_in_cgohio
21 posts in 1674 days
01-26-2016 12:53 AM
For some reason I just can’t figure this cut out. I want to cut a v-notch in a piece of hardwood. I am attempting to make a jig for holding pen blanks for drilling on the drill press. For the life of me I just cant get the notch to be a perfect v-shape. I end up cutting one side too deep. Anybody have a video showing how to do one? I am sure there is just some simple step I am missing.
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1176 days
#1 posted 01-26-2016 01:06 AM
Not in a table saw. For me this would be a job for the router, V shaped bit, and the Incra positioner.
View MrUnix's profile
MrUnix
6715 posts in 2199 days
#2 posted 01-26-2016 01:10 AM
Table saw at 45 degrees set to the right height… router with a v-bit… heck, I’ve even done it with a circular saw set to 45 degrees. However… you don’t need a ‘perfect’ vee, and it doesn’t even need to be a 90 degree vee… by design, just having any “V” will be self centering and what the small portion of the groove looks like doesn’t matter at all.
woodbutcherbynight
4562 posts in 2409 days
#3 posted 01-26-2016 05:05 AM
Table saw at 45 degrees set to the right height… router with a v-bit… heck, I ve even done it with a circular saw set to 45 degrees. However… you don t need a perfect vee, and it doesn t even need to be a 90 degree vee… by design, just having any “V” will be self centering and what the small portion of the groove looks like doesn t matter at all.
- MrUnix
Yup, mine may not be exact but it works. Look here
View Jim Finn's profile
Jim Finn
2656 posts in 2922 days
#4 posted 01-26-2016 01:20 PM
You could easily get a “Perfect V” cut using a sliding compound miter saw. That is how I have done it.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
jay_in_cgohio
#5 posted 01-26-2016 04:43 PM
Unfortunately all I have at the moment is the table saw. Guess I will just keep making sawdust until I figure it out. I know it should be as simple as moving the blade to 45 degrees and running the material over it. I either over or under cut the v.
View mrg's profile
mrg
824 posts in 2999 days
#6 posted 01-26-2016 04:52 PM
Cut two pieces at 45 degrees and but them up to form your V. Glue them to a backer,
-- mrg
