Pocket Hole Problems
« back to Joinery forum
Forum topic by wmgworks posted 01-25-2016 06:40 PM 1602 views 0 times favorited 36 replies Add to Favorites Watch
View wmgworks's profile
wmgworks
194 posts in 1225 days
01-25-2016 06:40 PM
I’m trying to build a set of saw horses. All 2×4 construction. One side of the set of legs is attached to he stretcher by pocket holes.. The other leg is attached to that leg via a hinge so they can fold up. Legs are mitered at 19 deg. The problem I’m having is the pocket screws do not seem to be grabbing the material correctly. This is my first time using pocket holes so I’m sure I’m doing something wrong here. I set the depth of the drill bit to 1 1/2” (the max on the K4) and the height of the holes to 1 1/2” (the max). I’m using coarse 2 1/1” kreg screws. On the end opposite this one, I actually pushed the screw through the stretcher a tiny bit. In this picture it shows that the unthreaded part has pushed through the leg. What am I doing wrong here?
-- Butchering wood since 2015
36 replies so far
View rwe2156's profile
rwe2156
3232 posts in 1720 days
#1 posted 01-25-2016 06:42 PM
I’m not surprised because pocket holes are one of the weakest joinery methods.
Use construction screws with or without glue.
View hotbyte's profile
hotbyte
991 posts in 3215 days
#2 posted 01-25-2016 07:23 PM
Looks like the hole is drilled too deep letting the unthreaded shank of screw extend past surface of wood. If the miter is on the piece you are drilling holes, the angle could be throwing everything off.
View Will Merrit's profile
Will Merrit
87 posts in 1133 days
#3 posted 01-25-2016 07:25 PM
Its what rwe2156 said, pocket holes are just not strong. A mortise and Tenon or some other joint would work.
https://www.youtube.com/watch?v=apsH8eBfjVA
View builtinbkyn's profile
builtinbkyn
2691 posts in 1180 days
#4 posted 01-25-2016 08:21 PM
Are you overdriving the screws? Meaning – countersinking them past the depth stop of the pocket because the torque of the driver is set too high? Also, the joint needs to be clamped before the screw is applied or it will push the opposing member out of alignment.
I don’t agree with the assessments that pocket hole joinery is “just not strong” or “one of the weakest joinery methods”, especially coupled with glue. However, though the other methods of joinery are stronger, they too are not always appropriate just as pocket holes aren’t always appropriate. M&T doesn’t work very well with plywood and other materials, where screws and glue excel.
Edit: The video was done well. Just wondering why the person who did the testing didn’t use glue with the pocket hole joints. That would probably make for a much better comparison. No arguing the other methods aren’t stronger. That’s an accepted principle.
-- Bill, Yo!......in Brooklyn & Steel City :)
View SirIrb's profile
SirIrb
1239 posts in 1470 days
#5 posted 01-25-2016 08:34 PM
Pocket screws are neither the second coming or El Diablo.
They are great in a production environment (with a machine, not jig) for face frames.
But as stated above, with saw horses glue it and screw it and forget it. I dont see pocket screws/holes buying a thing.
Face frames are about as fast and stronger if you have a boring machine.
Sorry to get off topic there.
Steve
Who has made more than his share of pocket holes and dowel holes, and if he believed voting made any difference would cast his for dowels.
Vote Dowels: Its for the children.
wmgworks
#6 posted 01-25-2016 08:36 PM
Here is the video of Steve Ramsey making them so I know the pocket hole screws will work for this.
http://woodworking.formeremortals.net/2014/06/build-a-folding-sawhorse/
I watched Steve put these things in over and over and over. All he does is prop the leg on his shoulder for support and screw it down into the cross member. I didn’t see him use any clamps or glue.
It’s entirely possible I overdrove the screws I guess. I’m also just starting to use an impact driver for the first time. How deep into the pocket hole should the head of the screw be?
View MT_Stringer's profile
MT_Stringer
3183 posts in 3471 days
#7 posted 01-25-2016 08:41 PM
For those of you that complain about poor joints with pocket hole sccews,,,I don’t think you have given them a fair shake. I use them for all sorts of stuff. The screws used by themselves hold really well.
I think the OP just needs to improve his technique. After all, it is his first time. It will get better.
wmgworks
#8 posted 01-25-2016 08:42 PM
- SirIrb
I think the reason he used Pocket holes maybe was to hide the screws underneath so you have less of a chance of hitting them with a saw blade. Not necessarily for a stronger joint (my guess). I saw this video a long time ago and was planning on just countersinking screws from the cross member into the legs instead of the other way around because I didn’t have a pocket hole jig at the time. Then one was generously gifted to me so I moved forward with the original concept.
View Reaperwoodworks's profile
Reaperwoodworks
94 posts in 1174 days
#9 posted 01-25-2016 08:45 PM
I disagree with pocket holes not being strong also. Different joinery works for different projects. It looks like maybe to much torque is being applied and the screws are being driven in too far. If you have the holes set 1-1/2” from from the edge and you are seeing that much of the smooth shank, that has to be whats happening.
On a side note, and I know you are pressed for space in your shop, but these are some quick, down and dirty sawhorses that work great. I just built a pair this morning: Sawhorses
-- Website: www.reaperwoodworks.com, Youtube: https://www.youtube.com/channel/UC_ognomZyK6V0VwdokBcixw
wmgworks
#10 posted 01-25-2016 08:45 PM
For those of you that complain about poor joints with pocket hole sccews,,,I don t think you have given them a fair shake. I use them for all sorts of stuff. The screws used by themselves hold really well.
- MT_Stringer
Thanks, Mike. That’s my thought, too. After I had this failure I went back to the Mere Mortals community threads on the build and saw no one else having this complaint. So I was pretty sure it was something I was doing. I’m not going to go to pocket hole screws every time Just Because. I’d like to make this work because i know it should, though.
wmgworks
#11 posted 01-25-2016 08:51 PM
- Reaperwoodworks
I think I ended up pushing them too far, too. But I kept pushing them because they didn’t feel like they were grabbing the cross member. There was always a little gap there. How far should the head of the screw be inside of the pocket hole?
I watched Jay’s video as well. Those are probably much easier to build than these. I really dig the way the one’s I am doing fold up, though.
hotbyte
#12 posted 01-25-2016 09:13 PM
I think I ended up pushing them too far, too. But I kept pushing them because they didn t feel like they were grabbing the cross member. There was always a little gap there. How far should the head of the screw be inside of the pocket hole?
I watched Jay s video as well. Those are probably much easier to build than these. I really dig the way the one s I am doing fold up, though.
- wmgworks
When using pocket holes, the two pieces need to be clamped/held together before driving the screw. They do not pull the joint together.
View ShaneA's profile
ShaneA
7064 posts in 2838 days
#13 posted 01-25-2016 09:18 PM
Yeah, clamping them together will do wonders for keeping them aligned, flush, and setting the screws properly. Used properly… pocket holes can make strong joints. Maybe not heirloom or extra points for being fancy, but easy and certainly have a place.
View paratrooper34's profile
paratrooper34
915 posts in 3191 days
#14 posted 01-25-2016 10:18 PM
My thoughts were the same as the two above me; you need to clamp the joint together (firmly) before driving the screws in. If you fail to do that, the result will be a separated joint as seen in the OP’s picture. Clamp them together and try again.
-- Mike
View Redoak49's profile
Redoak49
3743 posts in 2228 days
#15 posted 01-25-2016 10:24 PM
I am not a fan of using the impact driver for pocket hole screws. I am better with a drill driver as I can better feel how far they are going in. I tend to over drive them with an impact driver.
showing 1 through 15 of 36 replies
