pull down shelf hardware?
Forum topic by leftcoaster posted 01-25-2016 04:38 PM 882 views 0 times favorited 2 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
206 posts in 840 days
01-25-2016 04:38 PM
Topic tags/keywords: shelf pulldown hardware
Has anyone seen (or jury rigged) shelf hardware that could be pulled down and out (or just down) with a heavy item (my small air compressor) on the shelf? Shelf height over my bench is 8’ and I’d like to keep it that way, except if I need the compressor. Tiny shop so every inch counts.
I know there are things with pulleys—I was hoping for something spring loaded so I could just reach up and pull it down into position.
These things exist for kitchen cabinets to go UP—lifting a stand mixer out of a base cabinet. I haven’t found anything that goes DOWN.
Thanks
2 replies so far
View cstrang's profile
cstrang
1832 posts in 3131 days
#1 posted 01-27-2016 01:43 AM
I have installed these before in kitchens… not sure if that would be any good to you. poke around Richeleu’s site and you might find something to suit your needs. You cannot order direct from the site unfortunately because you need an account but you can find a local retailer to order through if you find something that works.
http://www.richelieu.com/ca/en/category/kitchen/upper-cabinets-storage-systems/pull-down-mechanism/pull-down-shelf/1033986
-- A hammer dangling from a wall will bang and sound like work when the wind blows the right way.
leftcoaster
#2 posted 01-27-2016 01:46 AM
Thanks for the suggestion. I think I happened on these at rev-a-shelf and was shocked to see a $4-500 price tag. If you are disabled and need accessible shelving, they are merciless with the pricing.
I think I’m just going to add an outlet with a switch and leave the compressor “on” with a hose attached. It’s not that far up so this should work out.
