Which finish can tolerate moderate heat?
Forum topic by tcot posted 01-25-2016 01:31 PM 634 views 0 times favorited 7 replies Add to Favorites Watch
View tcot's profile
tcot
3 posts in 972 days
01-25-2016 01:31 PM
Hi All;
I’m making a riser out of birch ply for my home brewing set-up.
Which finish should I use that will be able to withstand a pot of boiling water? The pot will be heated via an electrical element which is submerged in the pot, so the bottom of the pot will only be ~212F, as opposed to a pot removed from the stove.
I’d like to keep it simple…
Thanks,
Paul
7 replies so far
View BonPacific's profile
BonPacific
20 posts in 725 days
#1 posted 01-25-2016 04:53 PM
I’d look at finishes that people have recommended for Trivets, as this is effectively a very large trivet. From some googling around, seems like a lot of folks recommend using simple Mineral Spirits or leaving the wood bare. Some have reported success with Poly, but I really doubt that would survive intense heat.
View levan's profile
levan
472 posts in 2849 days
#2 posted 01-25-2016 06:06 PM
I THINK YOUR PLAYING WITH FIRE
You might want to consider metal or stone to keep it away from the wood. Maybe a riser of some sort
GOOGLE ignition point of wood
2. PHYSICAL CONSTANTS OF MATERIALS
Reactions to temperature exposure
Reaction Temperature (Celsius)
Wood slowly chars* 120°-150°
Decayed wood ignites 150°
Ignition temp of various woods 190°-260°
7 more rows
Physical Constants For Investigators – TC Forensic
www.tcforensic.com.au/docs/article10.html
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View Rick_M's profile
Rick_M
10811 posts in 2250 days
#3 posted 01-25-2016 06:12 PM
I used linseed oil + wax for a trivet, so far so good, but we only use it for a hot tea kettle.
Click for details
-- http://thewoodknack.blogspot.com/
Rick_M
#4 posted 01-25-2016 06:19 PM
- levan
Did you remember to convert from Celsius to Fahrenheit. OP is asking about 212F, not 212C.
Also you could use ipe which is fire resistant.
View dhazelton's profile
dhazelton
2646 posts in 2166 days
#5 posted 01-25-2016 09:48 PM
Does it have to be pretty? Cheapest and easiest way to go is screw down some cement backer board. It’s water resistant and fireproof. Dents easy but so what?
View Tennessee's profile
Tennessee
2672 posts in 2384 days
#6 posted 01-25-2016 09:54 PM
If you go into some of the Tex-Mex restaurant chains that sell the steak fajitas that come out on the pewter platter on an oak trivet, so hot it chars the oak trivet they carry it on over time, but they use those trivets for years. I don’t think they are required to wash them in a dishwasher, just wipe them off with a disinfectant.
I think they only have some sort of light oil finish on them, but I don’t know what it is. And also, I hate the smell of the burning oak when someone orders those doggone fajitas.
Personally, I think birch plywood is going to be FLAME ON…
View tcot's profile
tcot
3 posts in 972 days
#7 posted 01-25-2016 11:41 PM
Guys;
Thanks for the responses. I didn’t think to look at trivets. I’ll look after this…
I think the temperatures most are thinking of is that of a pan being taken off the stove. In that case, the bottom of the pan will be significantly hotter than boiling water.
In this case, the pot will never be hotter than boiling water, but it will be at that temperature for ~2hrs.
Does it need to look nice? Yes, it does. I briefly thought about tile, but it’ll be too heavy, and I don’t want to make it that complicated.
