What is the best way to remove bark from slab of mesquite
Forum topic by rrlumber posted 02-01-2010 07:22 PM 7321 views 0 times favorited 8 replies Add to Favorites Watch
View rrlumber's profile
rrlumber
25 posts in 3565 days
02-01-2010 07:22 PM
Topic tags/keywords: question trick resource
I have a 6” thick slab of mesquite that I want to use as a fireplace mantel. I have a “live edge” on one side that I would like to preserve. At this point the bark is still on the slab. Does anyone have any suggestions on the best method for removing the bark? I was thinking of using small grinder but I don’t want to damage the underlying wood.
Is there some kind of bark removal tool available?
Thanks,
rrwoodworker
-- Darrell, Round Rock
8 replies so far
View SnowyRiver's profile
SnowyRiver
51457 posts in 3722 days
#1 posted 02-01-2010 07:55 PM
I was wondering if you could get enough blade height out of the table saw to run it through on one side then flip it over and run it through again. It maybe possible to do it on a bandsaw too. Otherwise, use a drawknife. I used to use these alot to remove bark from fence posts and a sharp one works great.
-- Wayne - Plymouth MN
View Gene Howe's profile
Gene Howe
11168 posts in 3670 days
#2 posted 02-02-2010 12:11 AM
If it’s tight, I’d leave it.
If not, pry it off, piece by piece.
View John Gray's profile
John Gray
2370 posts in 4127 days
#3 posted 02-02-2010 12:15 AM
I’d try a PRESSURE WASHER.
View SawDustnSplinters's profile
SawDustnSplinters
321 posts in 4023 days
#4 posted 02-02-2010 12:28 AM
Well the rule of thumb I use is to leave the log air dry and when you can pull the bark off easily by hand it is ready to work with. You can pry it off otherwise..with small crowbars, chisels, etc…
-- Frank, Dallas,TX , http://www.allthingsrustix.com , “I have a REALLY BIG chainsaw”
View Timberwerks's profile
Timberwerks
360 posts in 3403 days
#5 posted 02-02-2010 12:58 AM
Using piano wire or a guitar string works very well. Make sure you wear leather gloves.
-- https://www.facebook.com/pages/Timberwerks-Studio/126415221682
117423 posts in 3819 days
#6 posted 02-04-2010 07:12 AM
How about a wire paint remover on a drill for the tough spots.
View borrows123's profile
borrows123
1 post in 3168 days
#7 posted 05-22-2010 09:25 AM
I think it is dangerous…
-- BORROWS
View uffitze's profile
uffitze
199 posts in 3197 days
#8 posted 05-22-2010 05:56 PM
drawknife
