Tips for glueing a ply cabinet?
Forum topic by lateralus819 posted 01-25-2016 02:37 AM 695 views 1 time favorited 9 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 1759 days
01-25-2016 02:37 AM
I’m having all kinds of problems getting my pieces to sit nicely in their dados.
I’m Making Dan phalens router table and I just spent the last hour trying to figure out the height of the two interior walls. I know the dado’s are .25” deep and from the divider up to the top of the sides is 17”. Therefor the interior walls must be 17.25”. Finally got it to seat. i was checking the height by placing a square on the outside wall and running it across the interior wall.
What are some ways to make sure it’s seating all the way across it’s length?
9 replies so far
View jmartel's profile
jmartel
7619 posts in 2020 days
#1 posted 01-25-2016 02:38 AM
Do you have curved cauls? That would put pressure along the entire length of the joint. Should help everything seat correctly. I use some 2×2’s from the local Home Depot. It even helps that they were never straight to begin with. I just picked some that had about 1/8” of curve along the length.
lateralus819
#2 posted 01-25-2016 02:46 AM
I have not, I have read about them. I will give them a shot. I think I saw a video on how to make them.
View MadMark's profile
MadMark
979 posts in 1323 days
#3 posted 01-25-2016 02:59 AM
Seat with a mallet & block. You can feel/hear when it’s fully seated.
M
lateralus819
#4 posted 01-25-2016 03:09 AM
I did try that with some success Mark. I don’t know what was throwing it off. I almost cut it too short Lol.
I’m going to make some cauls tomorrow cause I’m sure I’ll need them when I have to glue it up.
As it is I had to remake the interior panels because I was supposed to use 1/2” material for the slides. When I took it off I measured and good thing cause it was 1/16” too tall.
View MNgary's profile
MNgary
296 posts in 2287 days
#5 posted 01-25-2016 06:22 AM
You could draw a line 1/4 inch from the edge of the panels.
-- I dream of the world where a duck can cross the road and no one asks why.
View AlaskaGuy's profile
AlaskaGuy
3757 posts in 2179 days
#6 posted 01-25-2016 06:28 AM
Are your dadoes a consistent depth and have a flat bottom?
Just my opinion but if it takes hammer and a block of wood the put it together the dadoes are to tight. widen them up a bit.
View MrUnix's profile
MrUnix
6186 posts in 2069 days
#7 posted 01-25-2016 06:32 AM
If you haven’t already made some, these things work great for gluing up dados (and corners, and shelf butt joints, and… well, lots of ‘cabinet’ type stuff).
(courtesy of Izzy Swan – see this video for more info)
lateralus819
#8 posted 01-25-2016 10:56 AM
Are your dadoes a consistent depth and have a flat bottom? Just my opinion but if it takes hammer and a block of wood the put it together the dadoes are to tight. widen them up a bit.
- AlaskaGuy
Yes I used a router plane after to make sure they are.
View rwe2156's profile
rwe2156
2747 posts in 1351 days
#9 posted 01-25-2016 11:22 AM
Kevin,
I would rethink glueing. I don’t think standard wood glue alone is adequate with plywood. Epoxy would be better. This is because you’re dealing with mostly endgrain (actually worse than endgrain) on almost every aspect of the joint. Sizing the ends with glue is an option. In any plywood carcase, I think screws are the best route. You don’t even need any glue. You can countersink and plug.
A router plane gets your depth uniform but if the dados are too tight you either need to
1. Widen the dado (side rabbet plane or another pass on whatever you cut your dados with).
2. Reduce the thickness of the wood going in (block plane or sand).
