Dust Collection, What should I expect?
Forum topic by Konomigon posted 02-01-2010 05:34 PM 1207 views 0 times favorited 9 replies Add to Favorites Watch
View Konomigon's profile
Konomigon
55 posts in 3307 days
02-01-2010 05:34 PM
Topic tags/keywords: question tablesaw
Hi,
I am using a Rockler portable dust collecter on a Ridgid granite topped table saw. Its connected with a 21 section of flexible hose. What kind of results can I expect? So I still get tons of dust in the cabinet and very little dust is pulled out. Is this normal? I know I could probably seal up some of the holes in the saw, would this help the performance?
I should note that this is my first dust collection experience and maybe this is normal for tons of dust to pile up and then the collector just takes out the extra.
-- Kris
9 replies so far
View davidpettinger's profile
davidpettinger
661 posts in 3282 days
#1 posted 02-01-2010 05:59 PM
Dust collection is based on the movement of air. The farther the dust collector is away from where the dust is, the higher the CFM’s need to be. I have a 1500 CFM dust collector and the longest hose I use is 10 feet. The length of hose from saw to collector, I think, is what your problem is.
-- Methods are many,Principles are few.Methods change often,Principles never do.
View dbhost's profile
dbhost
5747 posts in 3313 days
#2 posted 02-01-2010 06:24 PM
A 1HP DC pulling through 21’ of ribbed hose? Yeah sounds about right… You either need a bigger DC, or a LOT less hose.
View SPalm's profile
SPalm
5321 posts in 3963 days
#3 posted 02-01-2010 08:34 PM
Yes. Seal up the holes that you can. Try some tests. Use 2” wide plastic sealing box tape (it is easier to remove later than duct tape) or duct tape if that is what you have. I am not sure of your particular saw, but typically the hole for the blade up/down is curved shaped so you can tilt. This can be a very big hole. Generally the only hole that you want to draw from is the slit for the blade. It is possible to starve the intake, but I doubt you are having that problem.
And shorten the hose. At least for a test.
Test, try, test. (It’s free.)
Steve
-- -- I'm no rocket surgeon
View PurpLev's profile
PurpLev
8539 posts in 3730 days
#4 posted 02-01-2010 08:44 PM
to maximize what you’ve got now, put the DC right behind the TS, and use 3-5ft of hose, nothing longer. also open the TS cabinet, and seal off any cracks in the cabinet lower and upper parts. you’ll still have some openings where the handwheels are, so don’t worry about over sealing it.
other than that – even with a Jet 1100 DC I still have dust left in the cabinet of the Ridgid TS on the sides – but whatever is inline with the DC port stays clean.
View 8iowa's profile
8iowa
1581 posts in 3842 days
#5 posted 02-01-2010 09:07 PM
Curiously, I just finished ripping about 25 board feet of hard maple (using a 24T rip blade). I noticed a much larger accumulation of dust than normal on the floor and table of the saw. Actually, the dust was in the form of strands rather than “dust” per se. A rip blade of course has deeper gullets and cuts much like a chisel.
When doing cross cuts, either with a combo or a crosscut blade, the dust is finer, and the DC sucks it up more efficiently. It is of course the fine dust that can become airborne that we are most interested in capturing
View MedicKen's profile
MedicKen
1615 posts in 3543 days
#6 posted 02-01-2010 09:16 PM
I agree with the above recommendations. more info can be found here Information
View Miket's profile
Miket
308 posts in 3853 days
#7 posted 02-01-2010 09:21 PM
Same here!
-- It's better to have people think you're stupid rather than open your mouth and remove all doubt.
dbhost
#8 posted 02-01-2010 09:35 PM
FWIW, it should be clarified. Dust above the table, and below are two different things. A zero clearance throat plate in particular keeps a great deal of the dust above the table, a guard with a dust port like a Shark Guard or other aftermarket guard will go a LONG way to keeping your shop air dust free. HOWEVER, your 1HP DC doesn’t have enough grunt to pull from both below, AND above the table. My 2HP would really be stretched to do that. I use a 2HP DC plus a shop vac, the DC gets below the table, the shop vac gets above the table…
View Rick  Dennington's profile (online now)
Rick Dennington
6006 posts in 3276 days
#9 posted 02-01-2010 10:11 PM
What all of the above said. What MedicKen, Miket, and dbhost said, too. Basically what everybody said.. That’s what I would say, if I had said it, but no need to say it… already been said. Somebody say something?
-- " It's a rat race out there, and the rats are winning....!!"
