| Forum topic by Chris | posted 746 days ago | 172 views | 0 times favorited | 5 replies | ![]() |
746 days ago |
746 days ago |
I don’t think I’ve ever had a jitterbug pneumatic sander, but I’ve had a circular sander. They use a lot of air to run, and the amount of electricity is more than operating an electric sander. The Campbell Hausfeld Jitterbug Sander uses 9.0 CU FPM at 90 lbs pressure. A lot of air on a home compressor. I don’t know if they are orbital or not. Here is one for sale. After looking at it I know I have one somewhere in the shop. Maybe I tried it, maybe not. Here is an interesting article on Jitterbug sanders. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
746 days ago |
Karson, My dad has a 60 Gallon heavy duty compressor that is mounted on concrete slab outside of his shop. The air supply is not a problem. Campbell Hausfeld huh? I’ll look them up…. Thanks! Anyone else have a suggestion? -- Chris |
746 days ago |
Chris Someone I know learned the hard way – don’t ask me how I know – but the key factor is to match the pressure required in psi and the air consumption in cfm of the tool to the capacity of the air compressor. This person I know now has a lovely and clean pneumatic sander and a lovely and clean air compressor. Don’t tell my – ahhh – his wife – please Cheers -- Mike, Maryland, www.thewoodenquill.com |
745 days ago |
Chris; The Jitterbug was origionally made by National Detroit, or Huchens, I believe. They were origionally used for auto body work. They were able to use 8 by 11 in. paper and one sheet was torn into three sheets. I have used origionals, and they use a lot of air, and remove a lot of material, depending on the grit of paper used. They are fixed orbital, instead of random orbital, which means that the pad was held by rubber feet so they did not turn. The tool will last many years. most important is how large of an orbit it takes. They will show that orbital motion as small circles on the wood. Is He planning on using it on wood, He may mean a random orbital. chech with auto stores, and your Dad before You buy -- Saved, and so grateful, consider who Created it ALL!!! |
745 days ago |
My buddy has one of those. He doesn’t use it much. Its kinda long and narrow, like Dutchman said I think it was designed to do auto body work. -- David, South Windsor, CT "I love the smell of sawdust in the morning" |
| Forum | Topics |
Woodworking Skill Share
2926 |
3961 |
258 |
955 |
225 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
