Card Scrapers... Which way to go??
Forum topic by iamwelty posted 01-31-2010 11:06 PM 1087 views 1 time favorited 7 replies Add to Favorites Watch
View iamwelty's profile
iamwelty
259 posts in 3079 days
01-31-2010 11:06 PM
I’ve never used them, but have heard they can do amazing work… Is one brand better than another; Lee Valley, Veritas, Bauco… Is straight the way to go? Curverd? Size? Thanks for your input!!
-- There is a fine line between eroticism and nausea...
7 replies so far
View papadan's profile
papadan
3584 posts in 3331 days
#1 posted 01-31-2010 11:21 PM
I have a couple different sets, brand don’t really matter. As for how to use them, I push and pull them depending on what the project and grain orientation is. Usually pull them at a slight angle to better cut the fibers. Hard to describe, best to watch someone using them I guess.
View WayneC's profile
WayneC
13753 posts in 4060 days
#2 posted 01-31-2010 11:27 PM
Check out this card scraper post by Todd. He has a video showing his approach.
http://lumberjocks.com/toddc/blog/11542
117061 posts in 3540 days
#3 posted 01-31-2010 11:31 PM
As Dan said you can push or pull them with the center bent in the middle. I think Charles Neil has a you tube video on how to use them.
I found a link
http://www.youtube.com/watch?v=OAYST--mtNo
View Brian024's profile
Brian024
358 posts in 3363 days
#4 posted 02-01-2010 12:39 AM
I’ve been using the Lee Nielsen set for a while, very happy with them. I’ve been finding that I get better results if I use it going from a 45 degree angle across the grain.
35111 posts in 4363 days
#5 posted 02-01-2010 12:55 AM
When using a card scraper you might find that nothing happens, change the angle just a little and try again. The angle might be different each time you use them. It depends on the bur that you got.
View hokieman's profile
hokieman
182 posts in 3717 days
#6 posted 02-01-2010 06:27 AM
I don’t think the brand means anything, really. Even the Lie Nielsen’s are moderately priced. They sound real difficult to prepare but they really aren’t that hard. In fact, I just prepared one today. Filed the edges down, flattened the faces and the edges on a water stone then drew the burr. Key is go easy when turning the burr. You don’t need to use excessive force. I don’t have any curved ones but I can see where they would come in handy.
As for how to use, I am better at pulling than pushing. Be careful though, they can burn you. Scrapers build up a lot of friction and they can get real hot pretty fast.
iamwelty
#7 posted 02-01-2010 03:01 PM
Thanks guys for the excellent suggestions!
