swivel stool
Forum topic by cathyb posted 01-31-2010 07:45 PM 1803 views 0 times favorited 7 replies Add to Favorites Watch
View cathyb's profile
768 posts in 3177 days
01-31-2010 07:45 PM
How do you attach the metal swivel plate to a stool? I have the instructions that Rockler provides online and I’m scratching my head. You attach the plate to the seat bottom with screws or bolts. Take it off, drill some pilot holes through the seat top, then reattach it to the bottom, put the top in place and add the screws. What??! I don’t want screws showing through the seat of my chair? I suppose I screw the plate to the top and then have bolts showing in the bottom of the seat but if it’s a bolt how do you tighten it? Has anyone made swivel stools?
-- cathyb, Hawaii,
7 replies so far
117032 posts in 3510 days
#1 posted 01-31-2010 07:51 PM
Or send a link or photo?
-- wood crafting & classes
View interpim's profile
1170 posts in 3392 days
#2 posted 01-31-2010 07:53 PM
if this is the plate
Then what you will want to do is line it up on the seat bottom where you want it… mark a spot in each slot, and use screws shorter than the thickness of the stool bottom. then screw it in.
-- San Diego, CA
#3 posted 01-31-2010 08:09 PM
Hi Dave,
The plate I ordered is #28894 on page #88. It will be here this week. I did order and received a smaller plate (#41202) but since my seat is 21” wide it seemed too small. When I received that plate, I was surprised that it didn’t come apart. As a rule, I never want fasteners visible and I guess it’s unavoidable. How do you get it tight. Another concern is that the specs say the swivel plate is 7/8”. Can it be recessed at all? That’s a pretty wide gap in my seat….........
-- cathyb, Hawaii,
View janice's profile
1116 posts in 3358 days
#4 posted 01-31-2010 09:28 PM
Hi Cathy, can’t help you much here, but isnt it great that you can post something and get answers with in minutes. I can tell you that my store bought bar stools have a 5/8” gap and it looks fine. Bolts do come thru the bottom too.
-- Janice
#5 posted 01-31-2010 10:01 PM
Hi Janice,
Okay that helps.
-- cathyb, Hawaii,
13598 posts in 3274 days
#6 posted 02-01-2010 12:28 AM
isn’t there a hole in the bottom part ,
it lines up with the screws for the top attachment ?
just spin the bottom and screw each one and go to the nextif it is square ,
put the bottom at a 45 deg. to the top and the screw holes should be accessible .
#7 posted 02-01-2010 03:35 AM
aha. I just got back from my neighbor’s house and her stool has that set up. Of course, if you drill a half inch hole in the bottom seat, there is plenty of space to fasten the screws to the underneath the seat top. I just was not willing to have screws (it would have been a bolts) coming out of the seat bottom. Why doesn’t Rockler use the hole approach? I makes more sense and it doesn’t detract from the look of the seat. Problem solved. Thanks for the replies. Pictures will be coming….....
-- cathyb, Hawaii,
